Forum Topic - bind error on TCP/IP connection: (8 Items)
I have an application where I am opening a TCP/IP socket, binding to a port then listening/accepting a connection from a
 client.
The problem I have is I want to be able to close the socket and later on create a new socket, bind to the same port and
listen/accept a connection.
What is happening is it works fine the first time.  However when I close the socket and later create a new socket, and
then try to bind it to the same port I get and EINVAL (22) error.  This docs say this means that the socket is already
bound to an address.
Seems that I am not closing the socket correctly, or should be doing an 'unbind' of some sort???!!!
I am calling close(sock) and have also tried doing a shutdown(sock,2) first.
Opening the socket I am doing the following (and this works the first time)
	sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
	setsockopt(sock, IPPROTO_TCP, TCP_NODELAY, (char *)&c_opt_on, sizeof(OPT_TYPE));
                 serverservice.sin_family = AF_INET;
	 serverservice.sin_port	= ntohs(nPort);
	serverservice.sin_addr.s_addr = INADDR_ANY;
 	    setsockopt(sock, IPPROTO_TCP, SO_REUSEADDR, (char *)&c_opt_on, sizeof(OPT_TYPE));
	    bind(sock, (sockaddr *)&m_serverservice, sizeof(m_serverservice));
The bind fails the second time and sets errno to 22.
Any ideas would be appreciated.
Thom
RE: bind error on TCP/IP connection
Have you tried SO_REUSEPOR?
> From: Thomas Allen [mailto:community-noreply@qnx.com]
> Sent: January-19-09 1:40 PM
> To: ostech-core_os
> Subject: bind error on TCP/IP connection
> port then listening/accepting a connection from a client.
> on create a new socket, bind to the same port and listen/accept a
> connection.
> close the socket and later create a new socket, and then try to bind it
> that the socket is already bound to an address.
> first.
> time)
> sizeof(OPT_TYPE));
> Thanks
> Thom
> http://community.qnx.com/sf/go/post20335
Re: bind error on TCP/IP connection
On Mon, Jan 19, 2009 at 01:40:15PM -0500, Thomas Allen wrote:
 a client.
and listen/accept a connection.
Set the SO_REUSEADDR socket option (setsockopt) before the bind.
Yes, I have set SO_REUSEADDR to 1 just before the bind (see code in original post).  I will do I check that it is
actually getting set.
> post).  I will do I check that it is actually getting set.
I just validated it by doing a getsockopt on SO_REUSEADDR just before the bind and it is definetly set to 1.  Any other
things I could try?
Thom
Hi Thomas:
	Is the client application that's using the socket closing it
when it's completed?
(Just as an aside, the Networking Project
http://community.qnx.com/sf/projects/networking would be the best place
for future questions like this.)
	Robert.
Sent: Monday, January 19, 2009 2:05 PM
To: ostech-core_os
Subject: Re: bind error on TCP/IP connection
> original post).  I will do I check that it is actually getting set.
the bind and it is definetly set to 1.  Any other things I could try?
Thom
OSTech
http://community.qnx.com/sf/go/post20344
Re: RE: bind error on TCP/IP connection
Ok I have found my bug.  When I was setting the SO_REUSEADDR I was using socket level IPPROTO_TCP instead of SOL_SOCKET.
     setsockopt(m_sock, SOL_SOCKET, SO_REUSEADDR, (char *)&c_opt_on, sizeof(OPT_TYPE));
Now with the correctly set all works.
Thanks for the help and pointing me at the SO_REUSEADDR.
> Sent: January-19-09 2:05 PM
> To: ostech-core_os
> original
Did you see my post about SO_REUSEPORT?
> Thanks
> Thom
