annonymous ftp seems to have a new problem under 6.3.2
08/09/2008 4:36 PM
post11608
I've been using annonymous ftp with QNX for some time. There was a problem with 6.3.0 that involved providing a usr/
lib directory, and a link from ldqnx.so.2 --> lib.so.2. This worked around some problem that had to do with using ls.
Now I've found that with the included ftpd, when I ftp in annonymously and run ls, I get an ugly message, and pipe has
crashed.
I used pkgsrc to build proftpd (which works quite nicely once you setup its configuration file), and while regular ftp
works fine, there is a similar problem using ls. Fortuitously it does not crash pipe, but annonymous ftp can only be
used blind.
Anyone know anything about how this can be repaired? There was talk a year or so ago at openqnx.com about a fix that
would work its way into a future release. Could this be the fix?
