qnx zynq interrupt handling
06/18/2018 10:20 PM
post118880
Hi QNX,
qnx Momentics 6.5.0SP1, bsp-xilinx-zynq7000-zc702-650sp1, Xilinx zc702 evaluation board
I have a zc702 evaluation board at hand, and download the BSP from the following link
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/XilinxZc702
In Xilinx vivado diagram, I added a PL-PS Interrupt Port, selecting from IRQ_F2P[15:0]. xparameters.h tells me the IRQ
number is 61.
/* Definitions for Fabric interrupts connected to ps7_scugic_0 */
#define XPAR_FABRIC_AXI_GPIO_0_IP2INTC_IRPT_INTR 61
However, QNX InterruptAttach always returns -1.
int irq = 61;
uintptr_t gpio_base = mmap_device_io(0x10000, XPAR_GPIO_0_BASEADDR);
int result = InterruptAttach( irq, &handler, &gpio_base, 0x10000, _NTO_INTR_FLAGS_PROCESS);
Please advise how to implement zynq PL-PS Interrupt in QNX, thanks in advance.
Mike
Re: qnx zynq interrupt handling
06/19/2018 2:35 AM
post118881
Hi MIke,
the "&" in "&gpio_base" looks strange to me...
Cheers,
-- ar
06/19/2018 3:45 AM
post118882
I used "&gpio_base" on beaglebone black with other post in this forum
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.newcode.topc27325
If I delete &, there will be a warning "passing argument 3 of 'InterruptAttach' makes pointer from integer without a
cast"
either way, I tried
int result = InterruptAttach( irq, &handler, gpio_base, 0x1000, _NTO_INTR_FLAGS_PROCESS);
return value of result = -1 .
Please help , thanks in advance
06/19/2018 3:48 AM
post118883
Just to be sure... did you call ThreadCtl(_NTO_TCTL_IO) prior to InterruptAttach()? What does errno say when
InterruptAttach() fails?
06/19/2018 4:21 AM
post118884
Hi Thomas,
Thank you for the advice,
I did missed ThreadCtl(_NTO_TCTL_IO) , now I added following lines in the main() function.
if (ThreadCtl(_NTO_TCTL_IO, 0) == -1) {
printf("ThreadCtl\r\n");
return (!EOK);
return result =5.
However, I still didn't get interrupt yet. Exact same thing happened as previous post on beaglebone black, i.e., gpio
pin bears correct value when button pushed, however, the program never enters interrupt handler.
My question is whether this IRQ number 61 is acknowledged by QNX when I used InterruptAttach, or QNX tends to assign its
own IRQ number.
Please advise, thanks in advance
Mike
06/19/2018 5:36 AM
post118885
Hi QNX,
I made more progress, but still not there yet. Now, the program will hang whenever I push the button. Below is the
source code,
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include <unistd.h>
#include <sys/neutrino.h>
#include <sys/syspage.h>
#include <sys/mman.h>
#include <hw/inout.h>
#include <hw/gpio.h>
#define XPAR_GPIO_0_BASEADDR 0x41200000 // buttons
int irq = 61;
static uint32_t irqcount = 0;
static void Delay1(volatile unsigned int count)
while(count--);
static const struct sigevent *handler(void *area, int id)
irqcount++;
return NULL;
int main(int argc, char *argv[])
return (!EOK);
// pin configuration ...
if(gpio_base == MAP_DEVICE_FAILED)
perror("Can't map device I/O");
return 0;
out32(gpio_base + 0x4, 0xFF); // 1 as inputs.
out32(gpio_base + 0x0128, 0x1); // IP IER: channel 1 enable
out32(gpio_base + 0x011C, 0x80000000); // GIER global enable
// InterruptEnable();
if(result == -1)
printf("InterruptAttach wrong\r\n");
else
printf("Attached IRQ ID0 = %d\r\n", result);
while(1)
Delay1(0xFFFFFF);
Delay1(0xFFFFFF);
Delay1(0xFFFFFF);
Delay1(0xFFFFFF);
printf("connected %u\n", irqcount);
munmap_device_io(gpio_base, 0x10000);
return 1;
Mike
06/19/2018 6:58 AM
post118886
I'm not sure, I do not known the Zynq, but but maybe You have to clear the GPIO interrupt manually in the Isr :
It shold be that is not done automatically by bsp Isr handler ....
Eventually, try with InterruptAttachEvent instate of InterruptAttach: its is much easy to debug.
mario
06/19/2018 9:58 PM
post118887
Hi mario sangalli,
thank you for the nice suggestions.
I tried InterruptAttach, the interrupt only occurred once, then program hung.
Attached IRQ ID0 = 5
Interrupt 1
add source code like follows,
struct sigevent event;
event.sigev_notify = SIGEV_INTR;
int result = InterruptAttachEvent( irq, &event, 0 );
if(result == -1)
else
while(1)
InterruptWait( 0, NULL );
InterruptMask( irq, result );
irqcount++;
printf("Interrupt %d\n", irqcount);
InterruptUnmask( irq, result );
If removing InterruptMask( irq, result ); then the interrupt will never stop even with one-time button push. Results
like below,
Interrupt 1
Interrupt 4984
Interrupt 4985
Interrupt 4986
Interrupt 4987
Interrupt 4988
Interrupt 4989
Interrupt 4990
Interrupt 4991
Interrupt 49
Please advise, thanks in advance,
Mike
06/20/2018 2:57 AM
post118889
Mike, You haven't to do the InterruptMask! interrupt is already masked, You have only to
unmask it when done with your stuffs.
Before unmask interrupt, during debug, You can look at GPIO registers and checks what's
wrong (ie: interrupt not clear or some other GPIO interrupt pending ...)
Anyway, I've downloaded the bsp just for curiosity: I've found in an interesting gpio library
You can look at the gpio lib sources, see xzynq_gpio.c and the xzynq_gpio_irq_clear(int pin) function.
It sound a usefull one: maybe You have to add the xzynq_gpio_irq_clear to Your code....
BTW, I've read in the Qnx 6.6 bsp release notes that gpio library has been fixed for some bugs:
maybe You can switch to 6.6 or You have to patch the 6.5 files using 6.6 one and recompile the
gpio lib (libgpio-xzync.a)
mario
06/20/2018 3:37 AM
post118890
Hi mario,
Thank you for the timely support.
The gpio lib sources in BSP package are for PS-GPIO. I have already successfully implemented PS-GPIO (arm side)
interrupt in early March, and recorded a previous post in this forum http://community.qnx.com/sf/discussion/do/listPosts
/projects.core_os/discussion.newcode.topc27341
What I am doing now is AXI-GPIO interrupt, which is implemented by FPGA, and could register interrupt through PL-PS
Interrupt Port, selecting from IRQ_F2P[15:0]. i.e., irq # =[61~68 | 84~91]
Xilinx product guide, Page 10, table 2-4 shows the register space (which is different from PS-GPIO).
https://www.xilinx.com/support/documentation/ip_documentation/axi_gpio/v2_0/pg144-axi-gpio.pdf
Mike
06/20/2018 4:42 AM
post118891
Mike,sorry, I've never used the zynq, I'm a bit confused about PS-GPIO and AXI GPIO :-)
Anyway, if the AXI GPIO are not equal to PS-GPIO, You have to add the support for the interrupt handling in the
init_intrinfo.c creating one or more entry and add the specific function to mask, unmask, eoi etc....
If the AXI GPIO requires a different way (or simply have a different base address) to handle mask, unmask and
eoi , You code will crash just after the interrupt assertion :-)
Maybe You can change the callout_interrupt_xzynq_gpio.s to adapt to AXI registers layout.
mario
06/20/2018 5:21 AM
post118892
Hi mario,
Thanks for the advice, though it sounds of lots of workload, I will try at later time.
Best
Mike
06/19/2018 10:17 PM
post118888
follow another post in this forum, https://openqnx.com/phpbbforum/viewtopic.php?t=7263
I added _NTO_INTR_FLAGS_TRK_MSK to InterruptAttachEvent, but did not make any difference.
int result = InterruptAttachEvent( irq, &event, _NTO_INTR_FLAGS_TRK_MSK );
