Forum Topic - QNX with SMP kernel is unstable (copied from General forum): (17 Items)
QNX with SMP kernel is unstable. For example, QNX hangs during QNX Momentics IDE 4.0.1 start: mouse and keyboard are
frozen. It works normally with uniprocessor kernel (with/without DMA).
Configuration (pidin/qconfig):
CPU:X86 Release:6.3.2  FreeMem:813Mb/990Mb BootTime:Mar 10 04:52:37 MSK 2008
Processor1: 263730 AMD ?86 F15M11S2 2213MHz FPU
Processor2: 263730 AMD ?86 F15M11S2 2213MHz FPU
QNX Installations
  Installation Name: QNX Momentics Development Suite 6.3.2
            Version: 6.3.2 x86-only
     Base Directory: /usr/qnx632/
           QNX_HOST: /usr/qnx632/host/qnx6/x86/
         QNX_TARGET: /usr/qnx632/target/qnx6/
Any ideas (except to work with uniprocessor kernel :-) ?
Is there anybody here who normally works with SMP kernel and at least two processors?
Vladimir
Re: QNX with SMP kernel is unstable (copied from General forum)
Can you try starting the IDE bound to one cpu (ie
on -C0 qde
and see if the problem exists?  It may be a java issue rather than a kernel problem.
Colin
> Momentics IDE 4.0.1 start: mouse and keyboard are frozen. It works
> 2008
> QNX Installations
> two processors?
> Thanks,
> Vladimir
> http://community.qnx.com/sf/go/post5760
cburgess@qnx.com
Thank you for the suggestion. I already tried it without success.
BTW: Photon works stable after "on -C 0 ph".
I tried also to rebuild SMP kernel with mkifs and [CPU=1] for the drivers in the build file. But mkifs doesn't accept
this attribute.
Best regards,
Vladimir
Hmmm, so Photon is unstable normally?
The next step is to check for a kernel crash.  Try redirecting the kernel
debug output to ser1 or ser2, by adding -K3f8.9600 or -K2f8.9600 as arguments
to startup-bios in your build file.
Also please add [+keeplinked] on the same line as procnto-smp - this will
leave a relocated procnto-smp.sym in your working directory.
Colin
> drivers in the build file. But mkifs doesn't accept this attribute.
> Best regards,
> Vladimir
> http://community.qnx.com/sf/go/post5879
cburgess@qnx.com
1) Normally Photon is unstable: when I create a terminal window and drag it then a tail is created on the screen and QNX
 hangs (no mouse/keyboard reaction). See attachment.
2) Unfortunatelly, I can try to implement your debug suggestions only in weekend. Too much work on my original work.
Best regards,
Vladimir
Attachment: Image P1010113.JPG 605.03 KB
I rebuild SMP kernel with your recommendations: -K3f8.9600 and +keeplinked. What are the next steps?
Thank you in advance,
Vladimir
P.S. As I understand /dev/ser1 is used to output kernel debug messages (?).
P.P.S. I'm not a professional in *nix world. Sorry for the silly questions.
> I rebuilded SMP kernel with your recommendations: -K3f8.9600 and +keeplinked.
> Vladimir
RE: QNX with SMP kernel is unstable (copied from General forum)
Next time the kernel crashes it will spit out a load of debug info.  You can
post
that (and the procnto-smp.sym) to this forum, and we can take a peek at what
might
have gone wrong.
Cheers,
Colin
  _____
From: Vladimir Faisulaev [mailto:vfaisulaev@luxoft.com]
Sent: Sat 22/03/2008 5:01 PM
To: ostech-core_os
Subject: Re: QNX with SMP kernel is unstable (copied from General forum)
Vladimir
OSTech
http://community.qnx.com/sf/go/post6038
<http://community.qnx.com/sf/go/post6038>;
Re: RE: QNX with SMP kernel is unstable (copied from General forum)
Sorry but I still don't understand how/where I will/should see "debug info."
Best regards,
Vladimir
You will see a QNX kernel dump come out the serial port.
It should look something like this...
Crash[0,0] at kerext_process line 253
or
Shutdown[0,0] S/C/F=11/1/11 C/D=f001517d/f00571ac state(c0)= now lock
[0]PID-TID= 1-1? P/T FL=00019001/08800000 "proc/boot/procnto-instr"
[0]ASPACE PID=7 PF=00001010 "proc/boot/devb-eide"
x86 context[efffcc28]:
0000: 08088cc8 b0359320 efff2c3c efffcc48 b0357f14 08088d10 efff2c10 000000f8
0020: b0323948 0000001d 00011296 efff2c24 00000099
instruction[b0323948]:
ff 08 75 0e 8b 02 83 c4 f4 83 c0 08 50 e8 8e f5 fe ff 8b 5d e8 c9 c3 90 55 89
stack[efff2c24]:
0000: b0357f14 00000003 08088cc8 b0317d3d b0357f14 b0359320 efff2c6c b033f692
0000: 8088d10 b033f49c efff2c5c b033f678 b0357f14 00000003 00100102 00000003
You can get more information on the format here - http://www.qnx.com/developers/docs/6.3.2/neutrino/technotes/proc_dump.
html
> info."
> Best regards,
> Vladimir
> http://community.qnx.com/sf/go/post6041
cburgess@qnx.com
The output on /dev/ser1 contains only timestamps. Something like that:
<20080326234802.843>
<20080326234805.015>
<20080326234834.140>
<20080326234837.015>
Nothing more.
Best regards,
Vladimir
This isn't something that our kernel emits.  Does any application have /dev/ser1 open?
> Nothing more.
> Best regards,
> Vladimir
> http://community.qnx.com/sf/go/post6175
cburgess@qnx.com
I commented devc drivers start in /etc/system/enum/devices/char .
No special apps is running (only Photon).
Best regards,
Vladimir
Sorry, only <EOT> is coming. Timestamp is from the tool that traps COM1 in Windows (QNX and Windows is connected via
null modem COM1<->COM1).
Best regards,
Vladimir
Any new suggestions to find/bypass SMP kernel instability are appreciated.
Best regards,
Vladimir
Good news: I found the source of QNX (Photon, QDE, etc.) with SMP kernel instability. After I switched from vesa to svga
 driver all above works stable.
Thanks all for the help,
Vladimir
Interesting - I'll forward this to the Photon graphics guys.
Thanks for your perseverance!
Colin
> instability. After I switched from vesa to svga driver all above works
> stable.
> Vladimir
> http://community.qnx.com/sf/go/post6273
cburgess@qnx.com
