Forum Topic - Create new BSP for Cirrus Logic EP93xx: (5 Items)
I have an embedded board using the Cirrus Logic EP9302. It is an ARM920T-based CPU with MMU and I/D caches running at
200MHz. It has 32MB RAM and 16MB of NOR Flash.
A BSP doesn't exist for this board, but I wanted to create one. So what is involved in creating a new BSP? Are there
existing documents detailing the procedure?
Thanks!
RE: Create new BSP for Cirrus Logic EP93xx
Hi Alex,
Please post BSP related questions to the "BSPs and Drivers" project forums.
	- Fred
Sent: September 14, 2007 10:19 AM
To: ostech-core_os
Subject: Create new BSP for Cirrus Logic EP93xx
ARM920T-based CPU with MMU and I/D caches running at 200MHz. It has 32MB RAM
involved in creating a new BSP? Are there existing documents detailing the
procedure?
Thanks!
OSTech
http://community.qnx.com/sf/go/post1199
Re: RE: Create new BSP for Cirrus Logic EP93xx
Hello Alex / Frederic..
Any updates on the above mentioned query? Please share if there was any progress on the above.. Many thanks for your
efforts..
Thanks and Regards,
-Vibhav
Re: Create new BSP for Cirrus Logic EP93xx
efforts..
Hi Vibhav,
As Fred's response indicated BSP related questions should be asked in
the BSP forum. Here is a link for you:
http://community.qnx.com/sf/discussion/do/listForums/projects.bsp/discussion
Ryan Mansfield
Hello Ryan,
Thanks for replying and redirecting me.. But after posting, I did do a quick search on the foundry community and didnt
find many references to Cirrus Logic EP93xx series.. Looks like QNX has not done much work on these range of processors.
. Is that perception right?
Thanks and Regards,
-Vibhav
