Forum Topic - Tranparent Distributed Processing: (3 Items)
Can i run 2 threads of the same process into 2 diferent CPU using TDP?
Re: Tranparent Distributed Processing
No. Two threads of the same process can run on different CPU in an SMP
system (since both CPU have access to the same memory). For TDP, each
CPU has its own individual memory so you can't run two threads from
the same process that way - they have to be in different processes.
It is as i thought.
Thanks Brian.
