03/30/2008 5:19 PM
post6283
> Unfortunaltely this is for 6.3.2
I think I found a way. I can look at each program environment variable and figure it out. We use script to start
programs and I can create a variable in these scripts that will point to the directory.
Now on the find how to read the environment variable of another process and I don't have Rob's Cookbook with me ;-(
> > Colin had fixed a "bug" in this area a few month ago, it should be in the
> > head branch, just
> > not in the released version (it is probably in a recent milestone build).
> > There was an intention
> > in the loader of maintaining the debug path information so that debug
> > clients could more
> > intelligently locate the source that they were debugging ... unfortunately
> > what it actually ended
> > up being used for 99% of the time was to get the process name of the running
> > process
> > (ever wonder why it was called DCMD_PROC_MAPDEBUG to get the process name?).
> > So after a group pow wow .. the functionality was changed to match what it
> > was being
> > used for vs its mostly theoretical used.
> > As a side note, this also fixed the problem where binaries build with
> > windows names
> > would end up not being recognized by utilities like pidin and slay.
> > Now ... I don't recall if the fullpath is maintained, enough that the node
> > information
> > is also present or not, but there is time yet to patch that.
> > Hope this helps,
> > Thomas
> > On Fri, Mar 28, 2008 at 5:00 PM, Mario Charest <mcharest@zinformatic.com>
> > wrote:
> > > I want to acheive the same thing that _cmdname does but remotely.
> > > I looked at _cmdname() but apparently the information is stuffed when the
> > > process starts.
> > > To give a little more background, under QNX4 if you do sin the process
> > > name you'd see included the path from where the executable was started
> from,
> > > not sure exaclty but we'd see the whole path and not just the executable
> > > name. Under QNX6 what I see is the name it was build under as given by the
> > > -o option at link time.
> > > Some of our script/programs need the ability to tell were the program was
> > > started from or its current directory.
> > > Suggestions?
> > > OSMeta
> > > http://community.qnx.com/sf/go/post6263
