Re: reinstall problem on OpenSUSE 11.0
04/22/2009 11:35 AM
post27760
Hi Chuck,
Can you be more specific - at what point does the installation fail?
When you start the install, do you see the following ouput from InstallShield Wizard:
Initializing InstallShield Wizard...
Preparing Java(tm) Virtual Machine...
Running InstallShield Wizard...
Can you also post the the log file generated by the installer (/tmp/installOptionalLog.txt) ?
Natalia
> I previously had the 6.4.0 SDP working but had to re-install ...
> The cksum and md5 are correct for my bin file (qnxsdp-6.4.0-200810211530-linux
> .bin).
> I have run the cleanup in between attempts to install and have tried (export
> LIBXCB_ALLOW_SLOPPY_LOCK=1) but to no avail I get the following messages and
> the install fails.
> libxcb: WARNING! Program tries to unlock a connection without having acquired
> a lock first, which indicates a programming error.
> There will be no further warnings about this issue.
> libxcb: WARNING! Program tries to lock an already locked connection,
> Any help would be appreciated.
> Thanks
04/22/2009 5:00 PM
post27831
I found a fix ... problem is related to the JRE.
sudo sed -i s/XINERAMA/FAKEEXTN/g /usr/lib/jvm/java-1.6.0-sun-1.6.0/jre/lib/i386/xawt/libmawt.so
the above will fix the problem...SDP6.4.0 now installs completely.
Chuck
