Forum Topic - Java license error trying to create a new project in IDE 4.01:
I just updated my Neutrino-hosted IDE to 4.01 from SP3, using the ide-4.0.1-20070810000-nto.sh installation package. It
all went smoothly, and the IDE came up fine. Howerver, when I try to create a new project, I get a "License Check
Failure", with deatils "no qnxlic in java.library.path", and that's as far as I can get. Any insight as to what I need
to do to get 4.01 working would be appreciated.
Re: Java license error trying to create a new project in IDE 4.01
before launching ide
export LD_LIBRARY_PATH=/lib/dll:/usr/lib:/lib
if you use qde script it will set it
That did the trick. Thanks!
Hello Kevin,
hum, How do you create a Java project, don't if I forgot to install something but I have nothing about Java projects in
the nto IDE.
