Re: debug or run 'hello world' program
04/28/2008 3:19 PM
post7419
You are on the machine running Neutrino? I think Doc describes how to
run remote applications, in this case you use Remote launch instead.
You said you are using Debug, does it work when you use Run instead? If
yes - you are missing debugger.
med taalabi wrote:
> Hello,
> I just wanted to get started with the development of programs under
> Momonetics 6.3.2.
> So I get the project 'First project' given as example, and wanted
> to debug it on the host machine; I must then use the launch configuration:
> ' C / C++ Local ' .
> I followed all the steps described in the Doc.
> After filling the launch configuration, I click 'debug' to run the
> program.
> Then, a small window opens with the message:
> ' Error creating session '
> There is nothing in the error log.
> The same window opens when I want to run directly the program, after
> specifying the launch configuration.
> How could I verify if I have permission to write in the target file
> system (/tmp)?
> since I am on the same machine, Shouldn't it be obvious?
> Thanks,
> Taalabi M.
> __________________________________________________
> Do You Yahoo!?
> En finir avec le spam? Yahoo! Mail vous offre la meilleure protection
> possible contre les messages non sollicités
> http://mail.yahoo.fr Yahoo! Mail
> http://community.qnx.com/sf/go/post7415
