04/24/2014 8:38 AM
post110026
I hooked up the BD-SL i.MX6 board to a 7" touch screen (http://boundarydevices.com/products/7-800x480-display/) and used
the latest BSP for it to build the appsmedia-sample image.
When I try to launch this image I get the screen calibration screen, only its colors are off (blue backgroud instead of
white) and the touch screen isn't working (I'm unable to "touch" the target).
I have used this BSP:
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/FreescaleImx6QSabreLite
without any modifications.
The U-Boot text upon boot is looking good (white) on the screen.
Below is the boot serial output, and a photo of the screen is attached.
Can anyone please help?
Thanks!
U-Boot 2013.10-00101-ge20f07c (Jan 22 2014 - 13:30:39)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
CPU: Temperature 53 C, calibration data: 0x5a05017d
Reset cause: POR
Board: SABRE Lite
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 256 Bytes, erase size 4 KiB, total 2 MiB
auto-detected panel wvga-rgb
Display: wvga-rgb (800x480)
In: serial
Out: serial
Err: serial
Net: using phy at 6
FEC [PRIME]
Hit any key to stop autoboot: 0
mmc1 is current device
reading QNX-IFS
44339764 bytes read in 1964 ms (21.5 MiB/s)
## Starting application at 0x10800000 ...
SCU_CONFIG = 00005503, 4 cpus
Enabling Dcache and MMU
L2 cache enabled
CPU0: L1 Icache: 1024x32
CPU0: L1 Dcache: 1024x32 WB
CPU0: VFP-d32 FPSID=41033094
CPU0: NEON MVFR0=10110222 MVFR1=01111111
CPU0: 412fc09a: Cortex A9 MPCore rev 10 792MHz
Detected i.MX6 Dual/Quad, revision TO1.2
PLL1 - System : 792MHz
PLL2 - System Bus : 528MHz
PLL3 - OTG USB : 480MHz
PLL4 - Audio : 36MHz
PLL5 - Video : 339MHz
PLL7 - Host USB : 480MHz
PLL8 - Enet : 50MHz
IPG clock : 66000000Hz
IPG per clock : 66000000Hz
UART clock : 80000000Hz
CSPI clock : 60000000Hz
AHB clock : 132000000Hz
AXI clock : 264000000Hz
EMI_SLOW clock: 29333333Hz
DDR clock : 528000000Hz
USDHC1 clock : 198000000Hz
USDHC2 clock : 198000000Hz
USDHC3 clock : 198000000Hz
USDHC4 clock : 198000000Hz
ENFC clock : 24000000Hz
decompressing...done
CPU1: L1 Icache: 1024x32
CPU1: L1 Dcache: 1024x32 WB
CPU1: VFP-d32 FPSID=41033094
CPU1: NEON MVFR0=10110222 MVFR1=01111111
CPU1: 412fc09a: Cortex A9 MPCore rev 10 792MHz
CPU2: L1 Icache: 1024x32
CPU2: L1 Dcache: 1024x32 WB
CPU2: VFP-d32 FPSID=41033094
CPU2: NEON MVFR0=10110222 MVFR1=01111111
CPU2: 412fc09a: Cortex A9 MPCore rev 10 792MHz
CPU3: L1 Icache: 1024x32
CPU3: L1 Dcache: 1024x32 WB
CPU3: VFP-d32 FPSID=41033094
CPU3: NEON MVFR0=10110222 MVFR1=01111111
CPU3: 412fc09a: Cortex A9 MPCore rev 10 792MHz
cpu_startnext: cpu1 -> fc411bd4
cpu_startnext: cpu2 -> fc411bd4
cpu_startnext: cpu3 -> fc411bd4
System page at phys:10023000 user:fc410000 kern:fc410000
Starting next program at vfe067e3c
cpu_startnext: cpu0 -> fe067e3c
VFPv3: fpsid=41033094
coproc_attach(10): attach fe083c34 (fe085b68)
coproc_attach(11): attach fe083c34 (fe085b68)
Welcome to QNX Neutrino 6.6.0 on the Freescale i.MX6Q Sabrelite (ARM Cortex-A9 MPCore)
Starting I2C1,2,3 driver (/dev/i2c1,2,3)...
Starting SD3 memory card driver...
Starting SD4 (microSD connector) memory card driver...
Path=0 - FREESCALE USDHC
Process 11 (dev-can-mx35) terminated SIGBUS code=3 fltno=5 ip=0106d0f8(/usr/lib/ldqnx.so.2@__generic_memset+0x58)
mapaddr=0006d0f8. ref=28001080
Starting rtc utility...
Starting SATA driver...
Starting Ethernet driver
Starting USB host1 and OTG port (host mode)...
target=0 lun=0 Direct-Access(0) - SD:65 SD4GB Rev: 3.0
setting env variables.
Starting Logging services...
Creating ram disk...
Path=0 - AHCI (generic)
Path=0 -
target=0 lun=0 Direct-Access(0) - ram Rev:
Ram disk Created.
Starting dumper
Starting PPS
pps: NOTICE: PPS initializing
pps: NOTICE: PPS attaching /pps
pps:...
