Forum Topic - Serial target (Momentics 6.5.0SP1 on Linux):
I got my target running, I get pdebug running, but now I need to connect to the target through Momentics. I can't seem
to create a target that uses a serial port (/dev/ttyS1). New target only gives me the option for networked targets. Am I
 doing anything wrong or is debugging through the serial port not supported on Momentics 6.5.0SP1?
  Sebastian
Re: Serial target (Momentics 6.5.0SP1 on Linux)
You cannot create qnx target using serial port because we can only do a limited interface though it.
You can open serial terminal, which allows file transfer OR you can do debugging over serial.
> the target through Momentics. I can't seem to create a target that uses a
> targets. Am I doing anything wrong or is debugging through the serial port not
> Thanks,
>   Sebastian
As Elena indicated, QConn is expecting to connect over a TCPIP connection. If the target has no other options, you
_could_ setup PPP over serial.  This of course would be a slow TCPIP connection but is workable is there is no network
interface available.
