02/05/2019 8:23 AM
post119474
"porting of existing third-party code should be done under Linux hosts"
After repeatedly trying to build on a windows host (and failing), I'm pretty sure Linux is the right approach. Thanks
Albrecht.
Re: BOOST QNX 7 (lib: Archive has no index)
03/12/2019 3:40 PM
post119578
Using Ubuntu to build:
bootstrap.sh --with-icu
./b2 toolset=qcc target-os=qnxnto threadapi=pthread link=static -l240 --layout=system --without-python cxxflags="-
Vgcc_ntox86_64 -Y_gpp" linkflags="-Vgcc_ntox86_64 -Y_gpp -lang-c++" -j7 > buildlog.txt 2>&1
However, when I attempt to build the boost test program which relies on libboost_regex I get:
make -j8 all
qcc -lang-c++ -Vgcc_ntox86 -c -Wp,-MMD,build/x86-debug/src/t2.d,-MT,build/x86-debug/src/t2.o -o build/x86-debug/src/t2.o
-Wall -fmessage-length=0 -g -O0 -fno-builtin src/t2.cpp
qcc -lang-c++ -Vgcc_ntox86 -o build/x86-debug/t2 -LC:/qnx700/target/qnx7/usr/pkg/lib/boost_1_69_x86_64 build/x86-debug/
src/t2.o -lboost_regex
C:/qnx700/target/qnx7/usr/pkg/lib/boost_1_69_x86_64\libboost_regex.a: error adding symbols: Archive has no index; run
ranlib to add one
