Forum Topic - Unable to start in graphics mode with QNX 7: (17 Items)
Hello. Hope someone can assist. We have just installed today VMWare 14.1.1 Workstation (64 bit) on a Windows 7 64 bit OS
 -> installed Ubuntu 16.04 LTS (64 bit); this OS is working fine.
Next, installed the VMWare version of (time limited for 30 days) QNX 7 using the software center -> browsed to the
installation folder and allow for VMWare to run this VMWare image. The image boots in text mode but appears to fail to
run if under graphics mode. Repeated the same procedure with the older QNX 6.5 ISO -> runs fine under VMWare with
graphics.
We are attempting to run the graphics version as follows:
# ./etc/graphics-start.sh <ENTER>
end up with a black screen with only the mouse pointer. Believe the screen driver is an issue. The VM is not locked and
we can close the VM fine.
Attempted to increase the ram size under VMWare - no difference.
Attempted to limit the graphics resolution under VMWare to 640x480 - no difference.
Any suggestions on what we are doing wrong?
Attachment: Image vmware_graphics.png 92.58 KB Image vmware_QNX65_ok.png 89.83 KB
Re: Unable to start in graphics mode with QNX 7
There’s a setting called virtualHW.version in the .vmx file for your virtual machine.  You might like to try setting it
 to 10.  The default value (which I think is 12) doesn’t allow graphics to work at least with SDP 7 (I don’t know
about 6.5).
bit OS -> installed Ubuntu 16.04 LTS (64 bit); this OS is working fine.
graphics.
and we can close the VM fine.
    http://community.qnx.com/sf/go/post118710
    To cancel your subscription to this discussion, please e-mail momentics-community-unsubscribe@community.qnx.com
Thank you Roger for your very prompt post. Attempted a mix of values including 10 for that parameter and still no video
(remains black). Attempted down to 7 for that field. Also configured the VMWare to emulate down to older workstation 6.5
-7.x
The mouse pointer does disappear near the middle of the screen so wondering if the issue is related to the colour
settings, yet the older QNX 6.5 boots just fine.
My .vmx file is attached.
Will test other ideas in the morning. Welcome other thoughts you may have to resolve.
Attachment: Text QNX_SDP.vmx 2.65 KB
You might run
slog2info –b screen
to get logging output from screen.  This might give a clue to you or someone else.  Unfortunately I don’t do much with
graphics these days so you’ve exhausted my one trick for getting graphics to work.
I have a vague memory that you had to select “Enable 3D graphics support” in the virtual machine settings.
video (remains black). Attempted down to 7 for that field. Also configured the VMWare to emulate down to older
workstation 6.5-7.x
    http://community.qnx.com/sf/go/post118712
The graphics solution has changed from QNX650 (Photon) to SDP 7.0 (screen/composition manager).
There's no desktop application in SDP 7.0 so you may be seeing just a mouse because no graphics applications are running
.    Do you see anything appear on the screen if you run 'sw-vsync'?
Hello. Thanks for the advice.
Read on the VMWare website that VMWare needs to be cycled to read the updated .vmx file so did that but still no
graphics.
Did check the box for 3D graphics but received a warning that the host does not offer this support.
I do not think we are running the sw-vsync command correctly. What is the proper way to launch this tool? Output is
attached.
Attachment: Image sw_vsync_output.png 11.73 KB Image vmware_3d_graphics.png 74.09 KB Text vmware.log 199.89 KB
Screenshot doesn’t show you running /etc/graphics-startup.sh, have you?  The logs show no sign of screen which I would
have expected even if it had failed.
graphics.
attached.
    http://community.qnx.com/sf/go/post118717
Attached is the log from a session after running ./etc/graphics-startup.sh script. There is a brief text flash display
of "starting screen" text and then all black. Using vi editor, confirmed this detail is correct from the text script.
Should we run again but with the:
slog2info -b screen
and then
Attachment: Image graphics_startup.png 7.44 KB Image sw_vsync_output.png 11.73 KB
Did you try running sw-vsync after running  /etc/graphics-startup.sh?  It’s not clear exactly what you’re doing.  If
screen was running properly it would just appear black since it never displays anything on its own accord.
You may have difficulty running additional commands in the console after starting screen since if nothing else, nothing
will appear on the screen so you might want to create a script that first runs /etc/graphics-startup.sh and then runs sw
-vsync.  Or if you can connect to the target over the network (I don’t know if sshd or telnetd are running) then you
could do it from another terminal.  When you run sw-vsync you’ll likely want to ensure the environment variables
LD_LIBRARY_PATH and GRAPHICS_ROOT are set as in the /etc/graphics-startup.sh script.
display of "starting screen" text and then all black. Using vi editor, confirmed this detail is correct from the text
script.
    slog2info -b screen
    and then
    http://community.qnx.com/sf/go/post118719
Updated the graphics-startup.sh script (copied below). Still black after waiting 30+ seconds..log is attached from this
session.
Our interest is to compile the devc-8250 and related PCI driver code to modify and/or debug for future possible designs.
 Perhaps consider to use a different and dedicated box, without VMWare?
Attachment: Text vmware.log 201.23 KB
revised script
Attachment: Image revised_graphics_startup.png 7.42 KB
You have to wait until after the ‘waitfor /dev/screen’ before you try running anything that requires graphics, screen
won’t have had a chance to finish its initialization.
On 2018-03-29, 11:58 AM, "kumar bhatia" <community-noreply@qnx.com> wrote:
    revised script
    http://community.qnx.com/sf/go/post118722
You didn’t include graphics-startup.sh.
You need to run slog2info after starting screen.  The log output you show has nothing from screen and it should, even if
 it fails.
this session.
designs. Perhaps consider to use a different and dedicated box, without VMWare?
    http://community.qnx.com/sf/go/post118721
I think the attached is now correct :) Concerned about the file errors. In the meantime, completely removed from VMWare
and also uninstalled this image using the Software Center tool. Then installed a fresh copy again and re-applied with
VMWare. Launched and observed that the hard disk led is very busy on first launch but hardly at all if restarted.
For example,
2018-03-29T12:16:48.438-04:00| vmx| I125: ConfigDB: Failed to load C:\Users\lab\AppData\Roaming\VMware\config.ini
2018-03-29T12:16:48.438-04:00| vmx| I125: OBJLIB-LIB: Objlib initialized.
2018-03-29T12:16:48.438-04:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\
ProgramData\VMware): Cannot create a file when that file already exists (183)
ProgramData\VMware\VMware Workstation): Cannot create a file when that file already exists (183)
2018-03-29T12:16:48.439-04:00| vmx| I125: FILE: FileCreateDirectoryRetry: Non-retriable error encountered (C:\
2018-03-29T12:16:48.439-04:00| vmx| I125: DictionaryLoad: Cannot open file "C:\Users\lab\AppData\Roaming\VMware\config.
ini": The system cannot find the file specified.
2018-03-29T12:16:48.439-04:00| vmx| I125: [msg.dictionary.load.openFailed] Cannot open file "C:\Users\lab\AppData\
Roaming\VMware\config.ini": The system cannot find the file specified.
2018-03-29T12:16:48.439-04:00| vmx| I125: PREF Optional preferences file not found at C:\Users\lab\AppData\Roaming\
VMware\config.ini. Using default values.
Attachment: Image revised2_graphics_startup.png 7.75 KB Text vmware.log 210.67 KB
I think we will give up on using VMWare with QNX 7.
Is there an ISO or similar install disk we can download and create to install QNX 7 on a blank drive on a dedicated PC?
From the Software Center, can only see the VMWare QNX installation (which for us is not working in graphics mode).
Thanks.
Hello. Was about to start drinking alcoholic beverages (I don't drink) and thought to email QNX. They prompted reply
with the following info which we must have missed...courtesy of Dennis Kelly of QNX:
Hi Kumar-
>>> VMWare which is yielding a black screen only upon launch with ./etc/graphics-startup.sh
The VMware image is behaving normally.
You must note the IP address (use ifconfIg) prior to starting graphics script.  Then, use putty in Windows to connect to
 the IP address of the VMware image and login as user “qnxuser” and password “qnxuser”.   (Once you start graphics
it clears the screen and you cannot use the PC console any longer.)  To prove graphics is working, run “gles2-gears”.
>> We will try this asap and post our results. Thanks for everyone for their assistance and hoping this will get us
moving. From what we have seen, there is no stand alone ISO image for this version of the OS. QNX 7 is based on the
VMWare platform which is fine, once it works for us :)
Proof that the graphics mode is now working :) After following the putty mode access stuff. Next hurdle is to compile
the driver code. Thanks again.
Attachment: Image qnx_graphics.png 126.32 KB
