Forum Topic - How to start code coverage using command line options?: (5 Items)
I have an executable built with code coverage enabled in it. If I launch this executable from the QNX IDE's code
coverage perspective, then I can see that code coverage data is being collected in my target (i.e. there are few *.da
files that get created).
However, if I run the executable using command line, then I dont see any *.da files being created. This should mean that
 the code coverage data is not being collected (correct me if I am wrong).
What are the command line options that I must provide to start code coverage? I need this info so that I can make use of
 code coverage in my project.
Sunil
Re: How to start code coverage using command line options?
Sunil Keshava wrote:
> Hello,
that the code coverage data is not being collected (correct me if I am wrong).
of code coverage in my project.
You need to compile with -ftest-coverage -fprofile-arcs.
For example:
$ qcc -ftest-coverage -fprofile-arcs hw.c
$  ./a.out
hello world
$ ls hw.da
hw.da
Ryan Mansfield
Thanks for the information Ryan.
But as I said in my post, I have already built my executable with the necessary code coverage changes made to the make
files, i.e. ftest-coverage -fprofile-arcs is being used during compilation.
But when I run the executable on my target, I do not see any files created on my target which indicate the code coverage
 information is being collected (no *.da files are being created).
I am wondering if some kind of arguments have be specified when I run the executable so that the OS knows that code
coverage information needs to captured.
Also please note that, if I launch the executable using the Code coverage perspective in the IDE, then I am able to see
code coverage info being captured. I am interested in seeing the code coverage info without having to use the IDE as a
launcher.
I hope I am more clear now. Please let me know if you need any other information to understand/solve my problem.
Sunil
As my example shows no options or arguments have to be specified when
running the executable for the code coverage information to be generated.
Does your program exit? Are you able to try a simple test like my
example? Are you using gcc 2.95.3 or 3.3.5? Can you provide an example?
Ryan Mansfield
I have not tried your example, let me try that and see how it goes. May be that will give some info which might help me
with my program.
Will get back to you soon.
Sunil
