problem with -finstrument-functions and qcc 4.2.4 on ARM
08/27/2009 3:19 PM
post36822
I've a shared object that is build using -finsturment-functions
source looks like this:
void get_my_addr() __attribute__((no_instrument_function));
void __cyg_profile_func_enter (void *this_fn, void *call_site) __attribute__((no_instrument_function));
void __cyg_profile_func_exit (void *this_fn, void *call_site) __attribute__((no_instrument_function));
unsigned get_my_addr() {
return __builtin_return_address(0);
void foo() {
TraceEvent( _NTO_TRACE_INSERTSUSEREVENT, 254, 0, 0);
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, 5, _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)get_my_addr(),
(unsigned)__builtin_return_address(0) );
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, 5, _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)foo,
I am satisfying the __cyg_profile_func_enter/exit functions on my own using this implementation:
void __cyg_profile_func_enter (void *this_fn, void *call_site) {
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, 5, _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)this_fn, (unsigned)call_site );
void __cyg_profile_func_exit (void *this_fn, void *call_site) {
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, 5, _NTO_TRACE_SYS_FUNC_EXIT, (unsigned)this_fn, (unsigned)call_site );
So now let us look at the results from a k-trace:
197147, 5s 561us, (393236) (7), Function Enter, function_addr 0x1041a4 call_site 0x15c8e4
197148, 5s 575us, (393236) (7), User Event 254, string d0 0 d1 0
197151, 5s 613us, (393236) (7), Function Enter, function_addr 0x1076adc call_site 0x15c8e4
197152, 5s 625us, (393236) (7), Function Enter, function_addr 0x1041a4 call_site 0x15c8e4
Line 1 is from compiler generated call to __cyg_profile_func_enter
Line 2 is the user TraceEvent 254 you see in the source
Line 3 is the self made enter event using a call to get_my_addr()
Line 4 is the self inserted event using the f-ptr
Looking at "function_addr" you see different values,
the problem is that the reported addresses are wrong expect the one that i get by calling get_my_addr()
The load address of the shared object from pidin mem is 0x1075000
you see the reported addresses do not match the load address.
any suggestions?
hp
Re: problem with -finstrument-functions and qcc 4.2.4 on ARM
08/27/2009 3:35 PM
post36823
Look like it's reporting the address in the plt
> void foo() {
> any suggestions?
> hp
> http://community.qnx.com/sf/go/post36822
cburgess@qnx.com
08/27/2009 3:48 PM
post36825
but that's not what it should!
08/27/2009 3:50 PM
post36826
Well let's confirm that that's what it's doing, first :-)
> http://community.qnx.com/sf/go/post36825
cburgess@qnx.com
08/27/2009 3:53 PM
post36827
OK, and let's also confirm that it is different from otherplatforms like Sh or x86
> > General
> cburgess@qnx.com
08/27/2009 4:16 PM
post36830
It will probably be the same.
I believe that what is happening is that address-of the
function is calculated. There must be a R_ARM_COPY
relocation for any site where address-of is taken so that
addresses match wherever they were taken from. TO confirm
this, you can print address of foo from your executable, it
should be the same as reported by trace.
I wonder if this would work: to calculate real address of
the function you can do
(unsigned)__builtin_return_address(0), (unsigned)call_site );
this should give address very close to real function start
(the address calculated should point to after prologue +
call to __cyg_profile_func_enter).
Aleksandar
>>> General
>> cburgess@qnx.com
> http://community.qnx.com/sf/go/post36827
08/28/2009 3:42 AM
post36848
Take a look at what I posted in my exampe,
that one is already doing all this once by using get_my_addr() and once using foo() symbol directly.
But this is missing my intention, I think this is a bug.
With this misfunction Address Translation feature is not working for ARM,
also Application Profiler feature is also not working.
Ask Elena whether she has an Application Profiler test case for a shared object on ARM.
/hp
08/28/2009 9:45 AM
post36866
The point is that called instrumentation function
(_cyg_profile_func_enter) should call __builtin_return_address.
I just compiled and run this:
printf("%s: this_fn: 0x%08x return_addr: 0x%08x
call_site: 0x%08x\n",
__func__, this_fn, __builtin_return_address(0), call_site);
The output is:
__cyg_profile_func_enter: this_fn: 0x0010054c return_addr:
0x010844b4 call_site: 0x001007a4
Maybe it is still a bug. Have you used our profiling
solution? I believe you can achieve the same effect with our
profiling solution by defining "QPROF_KERNEL_TRACE=1" env. var.
Will do.
Aleksandar
08/31/2009 4:14 AM
post36926
It can, but it should not have to.
It is defined that it gets the proper address.
I still think that this is a bug,
and I did a 2nd test for a simple binary (not a .so)
For this test it is working as expected.
I already did it this way by using the get_my_addr() implementation, see source from first post
I used it several times.
But in the past there were allways problems in profiling shared objects
The QPROF_KERNEL_TRACE=1 is not all you need, you also need at least QPROF_NO_MAIN=1
otherwise profiling wont start because main() is not instrumented,
but though, problems remained and I simply used my own minimal implementation.
08/31/2009 9:48 AM
post36952
It is not equivalent to what I suggested since your "foo"
function has to be modified to determine its own address.
The idea of instrumentation is to not have to modify
functions that are subject of instrumentation.
Interesting, from the current profiling library code, I see
we now ignore QPROF_NO_MAIN. It should not have any effect
at all. The library should just start profiling when first
instrumented function is executed (no matter where it is).
Tracing will auto start if one of QPROF_KERNEL_TRACE or
QPROF_FILE are given and unless QPROF_AUTO_START is set to '0'
What version are you using? What exactly was the problem,
maybe we can work on that and get it fixed for you?
Aleksandar
AW: problem with -finstrument-functions and qcc 4.2.4 on ARM
08/31/2009 10:09 AM
post36953
>The idea of instrumentation is to not have to modify functions
that was only for testing :-)
>>> Maybe it is still a bug. Have you used our profiling solution? I
>>> believe you can achieve the same effect with our profiling solution
>> objects The QPROF_KERNEL_TRACE=1 is not all you need, you
>also need at
>> least QPROF_NO_MAIN=1 otherwise profiling wont start because
>main() is
>> not instrumented, but though, problems remained and I simply
>Interesting, from the current profiling library code, I see we
>now ignore QPROF_NO_MAIN. It should not have any effect at
I didn't test the latest version
it has been a problem up to ... can't remember that excatly,
but I had a discussion on that in IDE forum with Elena
I will give current libprofilingS.a a try ...
but still behaviour is not as defined ;-)
cheers
hp
Management Board: Dr. Klaus Blickle (Chairman), Dr. Udo Huls, Michael Mauser
Re: AW: problem with -finstrument-functions and qcc 4.2.4 on ARM
08/31/2009 10:46 AM
post36957
You may be right, maybe there is a way to do a better job in
gcc, but right now this is how it works.
I will repeat that you can get good results with current gcc
by simply using __builtin_return_address(0) as I suggested.
You could even use dladdr in your __cyg_profile_...
implementation to retrieve symbol name; then use dlsym again
to calculate exact function entry.
Aleksandar
