RE: Mudflap, C++, and lenght of executable name.
08/11/2009 11:28 AM
post35707
> From: Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Sent: Tuesday, August 11, 2009 11:01 AM
> To: general-toolchain
> Subject: Re: Mudflap, C++, and lenght of executable name.
> It was supposed to be fixed, PR 65085.
> I will reopen it and revisit the issue.
Thanks, I'll wait for some feedback because maybe other stuff that should have been fixed looks like they have not. With
C++ program it's totally unusable. Reports memory leak for every global object (const std::string msg("this is a test"
); , as though the check is done before all these object destructors are called? Or maybe
The number of "read out of bounds" report in xstring, *stream and other are off the chart!
> Thanks for reporting,
> Aleksandar
> Mario Charest wrote:
> > Create a QNX C++ project, add mudflap support and build. Run/debug
> the application, all is fine. Now rename the executable to anything you
> like, but make it 14 character long or more. Run/debug the rename,
> memory fault!!!
> > General
> > http://community.qnx.com/sf/go/post35700
> http://community.qnx.com/sf/go/post35701
