Forum Topic - Debugging MultiThread application via GDB: (8 Items)
I use GNU gdb 6.8 qnx-nto (rev. 347) from 6.4.1 Windows Host.
GDB was configured as "--host=i386-mingw32msvc --target=arm-unknown-nto-qnx6.4.0".
I need to debug at least 2 threads independently. It means I want to stop thread 1 and step thread 2, then stop thread 2
, switch to thread 1 and step it. From gdb manual (http://sourceware.org/gdb/current/onlinedocs/gdb_6.html#SEC45) I've
read that it could be posible by non-stop mode. It seems above mentioned gdb does not support that mode.
Could you tell me please, how to debug multithreaded application?
Re: Debugging MultiThread application via GDB
Michael Kolesov wrote:
> Hello,
 2, switch to thread 1 and step it. From gdb manual (http://sourceware.org/gdb/current/onlinedocs/gdb_6.html#SEC45) I've
The documentation you are referring to is for the unreleased gdb 7.0.
non-stop debugging is not supported in gdb 6.8. In 6.8 gdb still stop
all threads, not just the current thread.
http://sourceware.org/gdb/download/onlinedocs/gdb_6.html#SEC45
Ryan Mansfield
Hmm..Top link gives me following:
This is the Ninth Edition, for GDB (GDB) Version 6.8.50.20090706
Ok, so what about scheduler-locking mode? As I understood I can switch to needed thread which will be always with the
top priority and step it..after that I can switch to another and again..Am I right?
I can do 'show scheduler-locking' and see 'off'. But I cannot set scheduler-locking on for qnx target. Is this feature
not supported?
And, when do you plan to port gdb 7.0 with non-stop debbuging mode :) ? May be you have any prerelease binaries or
needed sources to build 7.0 by myself..?
That is post-6.8 official release (or current HEAD sources).
This is how it is marked in the sources; once official next
release is created, the Version changes as well.
 not supported?
No, it is not.
Next SDP release (6.4.2) hopefully. We will have gdb 7.0,
but we might not support non-stop yet.
> http://community.qnx.com/sf/go/post33170
Aleksandar
Ryan, Aleksandar, thanks for explanation. I hope it will be..in respect to Neutrino which is a thread-based system ;)
Hello!
I see gdb 7.0 into svn. Any news about supporting of non-stop mode in Neutrino? Or any other features to debug
multithreaded applications?
Mike
RE: Debugging MultiThread application via GDB
Gdb 7.0 i still not official and hasn't been tested.
Non-stop mode is not currently supported and will not work with gdb 7.0, but we will eventually add it. There are no
firm dates or releases set for that.
What exactly do you mean by "features to debug multithread applications"? We have supported debugging multithread
applications for a long time. I would suggest gdb 6.8, the latest update from foundry.
Aleksandar
From: Michael Kolesov [mailto:community-noreply@qnx.com]
Sent: Sat 1/16/2010 4:51 AM
To: general-toolchain
Subject: Re: Debugging MultiThread application via GDB
Hello!
Mike
General
http://community.qnx.com/sf/go/post45355
Attachment: Text winmail.dat 2.9 KB
Re: RE: Debugging MultiThread application via GDB
Hi Aleksandar.
Thanks for new info.
Under "features to debug multithread applications" I have meat avalability to control the state (ready | suspend) of
application threads by myself (via debugger commands).
Of cause gdb 6.8 can debug multithead apps. But to debug a piece of code in desired thread you must have waiting
functions in all other thread at the moment. If not, gdb could switch to another thread without your desire. It is
normal and it calls reality :) but in some cases manual thread control is very handily.
Mike
