gcc -fstack-proctector problem?
06/23/2009 9:05 PM
post32389
This is on 6.4.1
I can see i386-pc-nto-qnx6.4.0 is compiled with -disable-libssp, but how come the gcc -c successed?
One of my project is using “gcc -c -fstack-protector" to test in configure, leads to mistakely allow that flag...
$ gcc --version
gcc (GCC) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ cat sp.c
int main()
$ gcc -c -fstack-protector sp.c
$ echo $?
0
$ gcc -o sp -fstack-protector sp.c
/usr/qnx641/host/qnx6/x86/usr/bin/ntox86-ld: cannot find -lssp_nonshared
collect2: ld returned 1 exit status
Re: gcc -fstack-proctector problem?
06/23/2009 9:18 PM
post32391
It would seem that the specs is still trying to bring in the libssp_nonshared when linking
Xiaodan Tang wrote:
> This is on 6.4.1
> $ gcc --version
> gcc (GCC) 4.3.3
> $ cat sp.c
> int main()
> $ echo $?
> 0
> http://community.qnx.com/sf/go/post32389
cburgess@qnx.com
06/23/2009 9:20 PM
post32392
Xiaodan Tang wrote:
> This is on 6.4.1
--disable-libssp only disables the building of the SSP runtime libraries
but it does not disable SSP altogether. The proper conf test should be
to link the executable.
What are you trying to build?
Ryan Mansfield
RE: gcc -fstack-proctector problem?
06/23/2009 9:24 PM
post32394
I am trying to build "cups" (pkgsrc/HEAD_641/print/cups), and was
confused about the failure of the linker.
If I took away the "-fstack-protector" in linking, you can see all those
_stack_guard/_stack_available function unresolved.
Looking at the configure, it test weather it should add this flag or
not, but do a "gcc -c -fstack-protector", which successed.
As of now, I am patching the configure to force it off to get going, but
thought this worth to mention.
-xtang
> From: Ryan Mansfield [mailto:community-noreply@qnx.com]
> Sent: June 23, 2009 9:20 PM
> To: general-toolchain
> Subject: Re: gcc -fstack-proctector problem?
> Xiaodan Tang wrote:
> > This is on 6.4.1
how
> > One of my project is using "gcc -c -fstack-protector" to test in
libraries
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post32392
06/23/2009 9:25 PM
post32395
Looks like someone has already proposed a fix to cups:
http://lists.busybox.net/pipermail/buildroot/2009-May/027475.html
Ryan Mansfield
>> -----Original Message-----
>> Xiaodan Tang wrote:
>>> This is on 6.4.1
> how
> libraries
>> Regards,
>> Ryan Mansfield
>> General
> http://community.qnx.com/sf/go/post32394
06/23/2009 9:29 PM
post32396
Cool, this is exactly what I am trying to do :)
-xtang
> Sent: June 23, 2009 9:26 PM
those
but
> Regards,
> Ryan Mansfield
> >> Xiaodan Tang wrote:
> >>> This is on 6.4.1
but
> > how
> > libraries
be
> >> Regards,
> >> Ryan Mansfield
> >> General
> > General
> http://community.qnx.com/sf/go/post32395
06/23/2009 9:37 PM
post32398
Ryan how is the libssp implemented?
> -xtang
> those
> but
>> Regards,
>> Ryan Mansfield
>>>> Xiaodan Tang wrote:
>>>>> This is on 6.4.1
> but
>>> how
>>> libraries
> be
>>>> Regards,
>>>> Ryan Mansfield
>>>> General
>>> General
>> General
> http://community.qnx.com/sf/go/post32396
cburgess@qnx.com
06/23/2009 9:55 PM
post32399
It sets random guard values at end of the stack frame, and then checks
to make sure they haven't been clobbered. The Linux implementations uses
routines provided by glibc (__stack_chk_guard/__pointer_chk_guard)
Ryan Mansfield
>> -xtang
>> those
>> but
>>> Regards,
>>> Ryan Mansfield
>>>>> Xiaodan Tang wrote:
>>>>>> This is on 6.4.1
>> but
>>>> how
>>>> libraries
>> be
>>>>> Regards,
>>>>> Ryan Mansfield
>>>>> General
>>>> General
>>> General
>> General
