Forum Topic - crash under 6.3.2 but not 6.4.1: (6 Items)
The following program will crash under 6.3.2.  The backtrace always looks like:
_list_release()
_prelocked_free()
__free()
free()
delete()
~facet() xlocale
~locale() xlocale
std::basic_ios<char.....> widen(char)
endl<....>
#include <string.h>
#include <stdio.h>
#include <unistd.h>
#include <sstream>
#include <pthread.h>
#define NUM 4
bool dye = false;
int count=0;
void *spitOutThread(void *arg)
	std::stringstream  myStream;
	try
		for(;dye != true ;)
			myStream << "this is a test" << std::endl;
			myStream.str("");
			++count;
	catch (...)
		printf("What?\n");
	return NULL;
int main(void) {
	int id[NUM];
	for( int i=0; i< NUM; ++i)
			pthread_create( &id[i], NULL, spitOutThread, NULL );
	sleep(5);
	dye = true;
	sleep(1);
	return 0;
Re: crash under 6.3.2 but not 6.4.1
> _list_release()
> _prelocked_free()
> __free()
> free()
> delete()
> ~facet() xlocale
> ~locale() xlocale
> endl<....>
I run the test program on a quad core machine.  If I limit it to one core with on -C1 it doesn't crash.  As a matter of
fact it seems it will only crash if it's allowed to use all for cores.
of fact it seems it will only crash if it's allowed to use all for cores.
Interesting. Have you always used the same level of
optimization? I am curious if compiling with -O0 would make
crash go away (on quad core machine)?
Aleksandar
RE: crash under 6.3.2 but not 6.4.1
> From: Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Sent: June-19-09 12:16 PM
> To: general-toolchain
> Subject: Re: crash under 6.3.2 but not 6.4.1
> core with on -C1 it doesn't crash.  As a matter of fact it seems it
I tried -O0  (cc main.cpp -ostream) no difference which isn't a big surprise given that the same executable runs fine on
 6.4.1. That tells me it's a library issue.
> Aleksandar
> http://community.qnx.com/sf/go/post32137
Re: RE: crash under 6.3.2 but not 6.4.1
> given that the same executable runs fine on 6.4.1. That tells me it's a
> library issue.
For anyone interested:  the problem seems to be in the library because if the code is compile with the gpp lib it
doesn't crash.
> > Aleksandar
> > General
I created TicketID88754 through standard support.
> _list_release()
> _prelocked_free()
> __free()
> free()
> delete()
> ~facet() xlocale
> ~locale() xlocale
> endl<....>
> #include <string.h>
> #include <stdio.h>
> #include <unistd.h>
> #include <sstream>
> #define NUM 4
> bool dye = false;
> int count=0;
> 	try
> 		for(;dye != true ;)
> 			myStream.str("");
> 			++count;
> 	catch (...)
> 		printf("What?\n");
> 	return NULL;
> int main(void) {
> 	int id[NUM];
> 	sleep(5);
> 	dye = true;
> 	sleep(1);
> 	return 0;
