Forum Topic - making svn under 6.4.x: (2 Items)
Since QSSL introduced the use of svn - I have followed up and now decided to port all my cvs repositories to svn.
This required the full complement of svn tools.  I downloaded the latest package with dependencies (1.6.2).
./configure worked after removing a couple of \" from the sed commands (lines 4312 and 4688).   BUT  svnadmin crashes
with what appears to be a compiler fault.
I have attached a sample session including a register dump.  IF I insert a printf(stderr,...) statement to report each
element of the indirect call, it works.  In other words, adding debug printf's appears to resolve the problem.
Unfortunately after that svn import..   did not work anyway.
What more info can I supply to help me get a svn server working under 6.4.  Obviously I cannot consider earlier versions
 of qnx since they do not have large file system support.
I used    ./configure --with-ssl  to set up (No Berkley db)
Attachment: Text svn.txt 3.41 KB
RE: making svn under 6.4.x
> From: Warren Deitch [mailto:community-noreply@qnx.com]
> Sent: May-18-09 8:08 AM
> To: general-toolchain
> Subject: making svn under 6.4.x
> (lines 4312 and 4688).   BUT  svnadmin crashes with what appears to be
> a compiler fault.
> insert a printf(stderr,...) statement to report each element of the
> 6.4.  Obviously I cannot consider earlier versions of qnx since they do
Check in the pkgsrc kit, maybe there is svnserver in there.
> http://community.qnx.com/sf/go/post29612
