Forum Topic - First steps with DevEnv 6.40.0 failure:
i am doing my first steps with the dev enviroment 6.4.0 under windows as dev host. But in spite of the good quickstart
guide the "hello world" program wil not run on the qnx target system. I work over the example project of the guide with
the "Welcome to the QNX Momentics IDE" text ...
When i try to start the compiled program on the target (release) i get the message "Could not find library libcpp.so.4"
... ok that is correct, this file is not on the target but on the filesystem of the windows host. So i tried to link
this lib static but i do not accomplish that ... so i copy this lib file directly in the directory on the target where
the binary will run.
At the next try the message "Could not find library libc.so.3" ... ok ... same procedure with this file ...
At the next try the message "Process 1769544 (MyTest_g) terminated SIGSEGV code=1 fltno=11 ip=7829bd9c mapaddr=00023d9c.
 ref=00000000" appears ... so a segmentation violation happened on the target.
I tried the same with the debug version: also a segmentation violation but before this message:
"warning: Host file D:/QNX640/target/qnx6/shle/usr/lib/ldqnx.so.2 does not match target file /usr/lib/ldqnx.so.2" ...
It seems that not the dev env is misconfigured but already the loader on the target machine crashes ... :-(
I have already take the qconn program from dev env instead of the qconn of my target ... no effect.
Here is some information about my target machine: http://www.250kb.de/u/090429/j/c8478dd4.jpg
Could anybody give me some hints for searching the reasons ..?
Thanx!
Frank
RE: First steps with DevEnv 6.40.0 failure
The target seems to have an older version of QNX.
> From: Frank Maier [mailto:community-noreply@qnx.com]
> Sent: April-29-09 9:56 AM
> To: general-toolchain
> Subject: First steps with DevEnv 6.40.0 failure
> as dev host. But in spite of the good quickstart guide the "hello
> example project of the guide with the "Welcome to the QNX Momentics
> IDE" text ...
> the message "Could not find library libcpp.so.4" ... ok that is
> windows host. So i tried to link this lib static but i do not
> on the target where the binary will run.
> SIGSEGV code=1 fltno=11 ip=7829bd9c mapaddr=00023d9c. ref=00000000"
> Thanx!
> Frank
> http://community.qnx.com/sf/go/post28340
Re: First steps with DevEnv 6.40.0 failure
If you have 640 host you should have 640 target. If you have 632 or earlier target you should have same version of
Momentics installed on host (they can co-exists).
You can use newer IDE with older momentics but re-targting it using env vars.
Frank Maier wrote:
" ... ok that is correct, this file is not on the target but on the filesystem of the windows host. So i tried to link
00023d9c. ref=00000000" appears ... so a segmentation violation happened on the target.
> Thanx!
> Frank
