Forum Topic - a.be.g vs a-be-g: (3 Items)
a.be.g vs a-be-g
I'm using IDE 4.5 and libstartup from the 8349 bsp is building the library into a.be.g.  In order to make it link with
the startup binary, I need a-be-g directory.  I've created a-be-g and it builds there as well, but I can't get it to
stop building in a.be.g.
If I delete the a.be.g or the a.be directories, they are recreated.
I am unable to locate anything in the common.mk file, why or where is this forced.  Should I just try to get the a.be.g
directories to work?
Kevin
Re: a.be.g vs a-be-g
Did you remove a.be.g when you created a-be-g?
g directories to work?
> Thanks
> Kevin
> http://community.qnx.com/sf/go/post27777
No...and it is working correctly now.
Thanks for responding.
