AW: AW: Trace logger info during system boot up
04/21/2009 3:14 AM
post27568
some things to check:
-what's the free mem after a normal startup -> pidin in
-is there any message on your console?
-just check a "tracelogger -n0 -s3.0 &" on your cmd line -> any error message?
>Von: Robin wood [mailto:community-noreply@qnx.com]
>Gesendet: Dienstag, 21. April 2009 09:09
>An: general-toolchain
>Betreff: Re: AW: Trace logger info during system boot up
>Hi,
>Thnx for your reply.
>To my surprise i dont see any tracelogger running also there
>kev file s also not seen on the path. I suspect it could be a
>memory issue so reduced to even 1MB but still the same result.
>With pidin ar below are the process running.
> pid Arguments
> 1 proc/boot/procnto-instr
> 2 devc-seromap -u1 -F -e -S -b115200 0xfffb0000^2,46,k
> 3 devf-generic -s0,32M -L1000 -r -f1
> 16388 inflator -v /rodata
> 16390 i2c-omap
> 20487 dspmgr -i /proc/boot/dsp_image.out -p30 -s1280 -b5912 -v1
> 32776 io-audio -odisable_sw_mixer -domap i2c_addr=26
> 40965 ipcl -o speed=1000 -p45
> 40969 devu-ohci -P25 -a0xfffba000 -i38 -vvvvvvvs
> 61451 ksh ksh
> 61452 PowerManagerProc -a1 -w1 -t2 -p50 -v
> 98318 pidin ar
>Pls let me know your comments
>General
>http://community.qnx.com/sf/go/post27566
