problem debugging core file
04/20/2009 4:03 PM
post27531
Use IDE 4.6.0 (april). Setup to use 6.3.2 tools. I notice the debugger has problem identifing threads in the core file.
I try updating too 6.8.u1 by copying the executable over the 6.3.2 file.
When launch the debug session I get a "Problem Occured" dialog with the following message:
Error creating session
Cannot access memory at address 0x8bd231e5
And the session terminates.
I manually launch gdb from outside the IDE and do see the error message come once but it's usable.
Re: problem debugging core file
04/20/2009 4:05 PM
post27532
What is the target architecture?
RE: problem debugging core file
04/20/2009 4:06 PM
post27533
Target is x86.
> From: Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Sent: April-20-09 4:06 PM
> To: general-toolchain
> Subject: Re: problem debugging core file
> http://community.qnx.com/sf/go/post27532
04/20/2009 4:16 PM
post27534
How do you run dumper? What options?
Note that gdb works the best with full cores. However,
threads should be read from a core's note. Do you see
anything for
"info threads"?
Also, could you try command line session, but first set
solib-search-path? Or simply copy all the libraries that
were loaded when core was generated to a directory where
your executable is, then change cur. dir. to that directory
and run gdb.
Does info shared look correct? Do all the symbols of the
shared libraries get found and loaded?
Aleksandar
04/20/2009 4:41 PM
post27537
> Sent: April-20-09 4:17 PM
dumper -w -z9
I do not understand ?
> However,
> anything for
> "info threads"?
Nothing shows up , but coreinfo shows the info about the 3 threads.
> solib-search-path?
Give: Cannot access memory at address 0x8bd231e5
> and run gdb.
All libraries are system libraries
- libc.so.2
- libc.so.3 (target is running 6.4.0 but the binary is 6.3.2)
- libcpp.so.4
- libz.so.2
- libm.so.2
- libsocket.so.2
When I run info shared I get the error message:
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post27534
04/20/2009 4:47 PM
post27540
dumper has options that create smaller dump files (like -m
for example). Typically you don't want to use any of them
(-w and -z are fine).
>> However,
>> anything for
>> "info threads"?
Odd.
>> solib-search-path?
>> and run gdb.
> - libc.so.2
> - libcpp.so.4
> - libz.so.2
> - libm.so.2
> - libsocket.so.2
That is odd; if you can, attach the executable and the core
so I can take a look.
How are you running gdb? What commands are you using?
Aleksandar
04/20/2009 4:51 PM
post27543
> >> However,
> >> anything for
> >> "info threads"?
> Odd.
Attached and compressed with 7zip.
/opt/qnx632/.../gdb file_server.exe file_server.exe.gdb (Linux host)
> Aleksandar
04/20/2009 5:00 PM
post27544
I reproduced it here. I will take a look and get back to you
soon.
Aleksandar
04/20/2009 5:01 PM
post27545
> Sent: April-20-09 5:01 PM
> soon.
Awesome, thanks Aleksandar!
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post27544
04/20/2009 5:15 PM
post27546
The core file has a corrupted PT_DYNAMIC segment.
Try the latest head dumper on your system Mario, see if it's any better.
Aleks - could this be PR63001?
>>>> However,
>>>> anything for
>>>> "info threads"?
>> Odd.
>> Aleksandar
> http://community.qnx.com/sf/go/post27543
cburgess@qnx.com
04/20/2009 5:50 PM
post27548
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: April-20-09 5:15 PM
Could this be an indication of something not quite right in my setup. I have a couple of programs doing a SIGBUS when a
machine on the network is turn off, quite a head scratcher.
> better.
A head dumper? That sounds like it's going to hurt, a lot.
> >>>> However,
> >>>> anything for
> >>>> "info threads"?
> >> Odd.
> >> Aleksandar
> > General
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post27546
04/20/2009 6:42 PM
post27552
>> -----Original Message-----
a machine on the network is turn off, quite a head scratcher.
If you use core file only, without executable, thread
information is being loaded as well as shared libraries. I
would think the core is good, but this suggests it doesn't
match the executable.
From the core, I get _r_debug to be at 0xb0873380 (and the
fact that shared libraries are correctly identified confirms
this is correct). However, looking at libc.so.3 versions I
have on my host, I could not find a matching one.
What exactly do you have on your target system? How did you
build the image? Yourself, or from the CD?
Aleksandar
04/21/2009 8:57 AM
post27592
It's a libc.so.3 given to us by QSS that fixes some C++ issues when a 6.3.2 program is run on 6.4.0.
It's a custom image with a bunch of unofficial patch for 6.4.0 and hybrid between 6.4.0 and unreleased 6.4.1 ;-)
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post27552
04/21/2009 9:08 AM
post27595
What about executable/core mismatch? You need exactly the
same binary that cored, but ideally with debug info (I see
the one you provided has debug info, but it's not the one
that generated the core).
Ok, just make sure you have matching libraries in your image
and your host-side momentics.
Aleksandar
04/21/2009 9:11 AM
post27596
> Sent: April-21-09 9:09 AM
Indeed my bad. However with a matching core and executable the result is the same. However the libc.so.3 on my host
machine doesn't match the target.
I copied all the .so files from the target in the same directory as the executable and core file is that good enough.
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post27595
04/21/2009 9:43 AM
post27612
That should work. Change your current dir to that directory,
then start gdb as you did before.
We, unfortunately, still don't have warnings for mismatching
libraries when examining core, but it's on my TODO list. For
now, you have to make sure yourself you get the right shared
libraries.
Note, however, that libraries you fetched from your target
(from your /proc/boot) will be stripped of some info that
gdb really likes (like most of the section headers) and it
would be ideal if you found the libraries that were used by
mkifs to create the image.
Another approach is to put exe/core in a directory (and
nothing else there) then start gdb:
$ gdb
(gdb) set solib-search-path thisdoesnotexist
(gdb) set solib-absolute-prefix thisdoesnotexist
This will "force" gdb not to find any symbols from shared
libraries. This should give you sane debugging session,
without, of course, all the comfort of printing symbol names
corresponding to the shared libraries. You should, however,
see threads, backtrace (instruction pointers) printed
correctly, symbols in the backtrace from your executable and
info shared should be correct. Also, you should see your
process died due to SIGBUS.
Hope this helps,
Aleksandar
04/20/2009 7:40 PM
post27553
If the program is being launched from the remote node (or has mmap()ed files from that node), then a SIGBUS is expected
when the next pagefault happens.
Dumper hasn't changed a lot since 6.4.0, except for a stack bug.
I wonder if it's freaking out trying to dump your dying process... I have a theory but will get back to you later...
Sent: Mon 4/20/2009 5:50 PM
Subject: RE: problem debugging core file
> better.
> >>>> However,
> >>>> anything for
> >>>> "info threads"?
> >> Odd.
> >> Aleksandar
> > General
> cburgess@qnx.com
General
http://community.qnx.com/sf/go/post27548
04/21/2009 8:56 AM
post27591
> Sent: April-20-09 7:40 PM
> files from that node), then a SIGBUS is expected when the next
> pagefault happens.
Yes the file is loaded from another node, what I do not understand is that only C++ program that will generated an
exception upon not being able to access a file from that same node with generated a SIGBUS. The other programs (all
loaded from that node) keep on running.
Does a C++ exception somehow trigger a pagefault?
> I have a couple of programs doing a SIGBUS when a machine on the
> > better.
> > >>>> However,
> > >>>> threads should be read from a core's note. Do you see anything
> > >>>> for
> > >>>> "info threads"?
> threads.
> > >> Odd.
> > >>>> Does info shared look correct? Do all the symbols of the shared
> > >> That is odd; if you can, attach the executable and the core so I
> > >> can take a look.
> host)
> > >> Aleksandar
> > > General
> > cburgess@qnx.com
> > General
> http://community.qnx.com/sf/go/post27553
04/21/2009 9:19 AM
post27600
I imagine it's simply touching a page of data/code that hasn't been loaded in yet. A pagefault that cannot
be satisfied (since the node has gone away) will cause a SIGBUS.
It looks like dumper will then try to read the pages from the remote node which will of course fail, but
dumper just writes out garbage as a result.
I'll raise a new PR.
>> pagefault happens.
>>> better.
>>>>>>> However,
>>>>>>> for
>>>>>>> "info threads"?
>> threads.
>>>>> Odd.
>>>>> can take a look.
>> host)
>>>>> Aleksandar
>>>> General
>>> cburgess@qnx.com
04/21/2009 9:23 AM
post27605
> Sent: April-21-09 9:20 AM
Is there a way to force the code/data to be loaded at startup. I always assume the code/data was loaded at startup.
This seems extremely unrealtime to me?
> mmap()ed
> >> pagefault happens.
> that only C++ program that will generated an exception upon not being
> other programs (all loaded from that node) keep on running.
> setup.
> >>> better.
> >>>>>>> However,
> >>>>>>> for
> >>>>>>> "info threads"?
> >> threads.
> >>>>> Odd.
> >>>>>> Cannot...
04/21/2009 9:37 AM
post27610
You can turn off lazy pagefaulting with -mL to procnto or mlockall() in your program.
Scratch that - I just analysed the core file further and it is sane - it's the executable mismatch that appears
to be the problem.
>> mmap()ed
>>>> pagefault happens.
>> setup.
>>>>> better.
>>>>>>>>> However,
>>>>>>>>> for
>>>>>>>>> "info...
04/20/2009 5:58 PM
post27549
How did you determine that?
I am not sure; I don't see this core being corrupt - what am
I missing?
04/21/2009 9:13 AM
post27597
cburgess@titirangi100:~$ ntox86-gdb file_server.exe
GNU gdb 6.7 qnx-nto
Copyright (C) 2007 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu --target=i386-pc-nto-qnx6.3.0"...
(gdb) info files
Symbols from "/home/cburgess/file_server.exe".
Local exec file:
`/home/cburgess/file_server.exe', file type elf32-i386.
Entry point: 0x804eed4
0x080480f4 - 0x08048108 is .interp
0x08048108 - 0x08048c88 is .hash
0x08048c88 - 0x0804a9f8 is .dynsym
0x0804a9f8 - 0x0804d294 is .dynstr
0x0804d294 - 0x0804d642 is .gnu.version
0x0804d644 - 0x0804d664 is .gnu.version_r
0x0804d664 - 0x0804d6ac is .rel.got
0x0804d6ac - 0x0804d7e4 is .rel.bss
0x0804d7e4 - 0x0804df7c is .rel.plt
0x0804df7c - 0x0804df89 is .init
0x0804df8c - 0x0804eecc is .plt
0x0804eecc - 0x08174864 is .text
0x08174864 - 0x0817486c is .fini
0x08174880 - 0x0818bd20 is .rodata
0x0818cd20 - 0x0818d488 is .data
0x0818d488 - 0x081b87c8 is .eh_frame
0x081b87c8 - 0x081d069c is .gcc_except_table
0x081d069c - 0x081d0784 is .dynamic
0x081d0784 - 0x081d0878 is .ctors
0x081d0878 - 0x081d0954 is .dtors
0x081d0954 - 0x081d0d50 is .got
0x081d0d60 - 0x081e9a60 is .bss
(gdb) x/32w 0x081d069c
0x81d069c <__FRAME_END__+98008>: 0x00000001 0x00000001 0x00000001 0x00000072
0x81d06ac <__FRAME_END__+98024>: 0x00000001 0x000000ef 0x00000001 0x000002f4
0x81d06bc <__FRAME_END__+98040>: 0x00000001 0x000022a1 0x0000000c 0x0804df7c
0x81d06cc <__FRAME_END__+98056>: 0x0000000d 0x08174864 0x00000004 0x08048108
0x81d06dc <__FRAME_END__+98072>: 0x00000005 0x0804a9f8 0x00000006 0x08048c88
0x81d06ec <__FRAME_END__+98088>: 0x0000000a 0x0000289c 0x0000000b 0x00000010
0x81d06fc <__FRAME_END__+98104>: 0x00000015 0x00000000 0x00000003 0x081d0954
0x81d070c <__FRAME_END__+98120>: 0x00000002 0x00000798 0x00000014 0x00000011
(gdb) target core file_server.exe.core
warning: exec file is newer than core file.
Cannot access memory at address 0x8b14ec83
0x81d069c <__FRAME_END__+98008>: 0xb0319790 0xb0319070 0xb031f6f0 0xb035a780
0x81d06ac <__FRAME_END__+98024>: 0xb03208a0 0xb035a7d0 0xb031a180 0xb0367080
0x81d06bc <__FRAME_END__+98040>: 0xb0342280 0xb0354f00 0xb031e5b0 0xb03594f0
0x81d06cc <__FRAME_END__+98056>: 0xb0321250 0xb0354e90 0xb03293f0 0xb82c1f90
0x81d06dc <__FRAME_END__+98072>: 0xb031f840 0xb035abe0 0xb03195c0 0xb03598d0
0x81d06ec <__FRAME_END__+98088>: 0xb031e600 0xb033a5ac 0xb034fae0 0xb828c4e0
0x81d06fc <__FRAME_END__+98104>: 0xb0329e60 0xb0319490 0xb828e280 0xb034e3f0
0x81d070c <__FRAME_END__+98120>: 0xb033af38 0xb035a440 0xb82850a8 0xb03429f0
(gdb) quit
> I missing?
> http://community.qnx.com/sf/go/post27549
cburgess@qnx.com
