Deciphering Function prologue and epilogue for PPC-based code
03/26/2009 3:49 PM
post25397
Hi:
I am trying to decipher the function prologue and epilogue code for setting up and unwinding the stack. The code is c++
and compiled under qcc (3.3.5) for our PPC405 processor. My understanding from reading the PPC EABI docs is that R1 is
treated as the stack pointer. The steps for setting up a new stack frame are to decrement the current SP to account for
the new frame, save the old SP in this frame (the back chain pointer) and also save the return address (Link Register)
in the slot in the previous stack frame. All makes sense.
However, the prologue/epilogue code for my function also includes saving/restoring register R31 which appears to be
operating as a frame pointer. However I don't see why when R1 and R31 always seem to be pointing to the same thing. So
my questions:
1) Why bother with preserving R31 when one can access all fields in the current frame by just using R1?
2) Why are 48 bytes reserved for the frame when less than that is actually used for storing frame header + parameters +
local vars?
Here is the code. Note it is a C++ function.
void Test::send(unsigned int value)
480405f4: 94 21 ff d0 stwu r1,-48(r1)
480405f8: 7c 08 02 a6 mflr r0
480405fc: 93 e1 00 2c stw r31,44(r1)
48040600: 90 01 00 34 stw r0,52(r1)
48040604: 7c 3f 0b 78 mr r31,r1
48040608: 90 7f 00 08 stw r3,8(r31)
4804060c: 90 9f 00 0c stw r4,12(r31)
unsigned int x = m_id;
48040610: 81 3f 00 08 lwz r9,8(r31)
48040614: 80 09 00 00 lwz r0,0(r9)
48040618: 90 1f 00 10 stw r0,16(r31)
m_dir = value;
4804061c: 81 3f 00 08 lwz r9,8(r31)
48040620: 80 1f 00 0c lwz r0,12(r31)
48040624: 90 09 00 04 stw r0,4(r9)
Test* p = this;
48040628: 80 1f 00 08 lwz r0,8(r31)
4804062c: 90 1f 00 14 stw r0,20(r31)
printf("This is me %u at 0x%p\n", x, p);
48040630: 3d 20 48 04 lis r9,18436
48040634: 38 69 07 c4 addi r3,r9,1988
48040638: 80 9f 00 10 lwz r4,16(r31)
4804063c: 80 bf 00 14 lwz r5,20(r31)
48040640: 4c c6 31 82 crclr 4*cr1+eq
48040644: 48 00 12 f9 bl 4804193c <_edata+0x4c>
48040648: 81 61 00 00 lwz r11,0(r1)
4804064c: 80 0b 00 04 lwz r0,4(r11)
48040650: 7c 08 03 a6 mtlr r0
48040654: 83 eb ff fc lwz r31,-4(r11)
48040658: 7d 61 5b 78 mr r1,r11
4804065c: 4e 80 00 20 blr
robert
Re: Deciphering Function prologue and epilogue for PPC-based code
03/26/2009 5:12 PM
post25405
Robert D'Attilio wrote:
> Hi:
+ and compiled under qcc (3.3.5) for our PPC405 processor. My understanding from reading the PPC EABI docs is that R1 is
my questions:
I am no expert on the topic; but are you sure it is always
pointing to the same thing? I did a quick test with a simple
virtual function and in it I see r31 being saved and then
"this" pointer loaded into it (Note: compiled with gcc 4.3.3).
4804613c: 94 21 ff b0 stwu r1,-80(r1)
48046140: 7c 08 02 a6 mflr r0
48046144: 90 01 00 54 stw r0,84(r1)
48046148: 93 21 00 34 stw r25,52(r1)
4804614c: 93 41 00 38 stw r26,56(r1)
48046150: 93 61 00 3c stw r27,60(r1)
48046154: 93 81 00 40 stw r28,64(r1)
48046158: 93 a1 00 44 stw r29,68(r1)
4804615c: 93 c1 00 48 stw r30,72(r1)
48046160: 93 e1 00 4c stw r31,76(r1)
48046164: 7c 79 1b 78 mr r25,r3
48046168: 7c 9f 23 78 mr r31,r4
Aleksandar
+ local vars?
> m_dir = value;
> Test* p = this;
> Thanks
> robert
> http://community.qnx.com/sf/go/post25397
03/26/2009 5:51 PM
post25408
Hi Robert,
I would guess by the look of it that the fragment is from an unoptimized
compile. In that case r31 is the environment pointer (which points to
the function's locals); and the stack frame is big enough to hold
everything, padded to a multiple of 16 bytes (per the ELF ABI).
An optimized build wouldn't have bothered with much of that - under
4.2.4 at O2, you'd get something more like:
00000000 <_ZN4Test4sendEj>:
4: 94 21 ff f0 stwu r1,-16(r1)
8: 7c 65 1b 78 mr r5,r3
c: 90 01 00 14 stw r0,20(r1)
10: 90 83 00 04 stw r4,4(r3)
14: 80 03 00 00 lwz r0,0(r3)
18: 3c 60 00 00 lis r3,0
1c: 38 63 00 00 addi r3,r3,0
20: 7c 04 03 78 mr r4,r0
24: 4c c6 31 82 crclr 4*cr1+eq
28: 48 00 00 01 bl 28 <_ZN4Test4sendEj+0x28>
2c: 80 01 00 14 lwz r0,20(r1)
30: 38 21 00 10 addi r1,r1,16
34: 7c 08 03 a6 mtlr r0
38: 4e 80 00 20 blr
Neil
On Thu, 2009-03-26 at 15:49 -0400, Robert D'Attilio wrote:
> Hi:
my questions:
+ local vars?
> m_dir = value;
> Test* p = this;
> Thanks
> robert
RE: Deciphering Function prologue and epilogue for PPC-based code
03/27/2009 5:09 PM
post25485
Neil & Aleksander:
Your right the code was compiled without optimization. Still I don't see
why the compiler bothers with using r31 as the environment pointer for
the functions locals when it could just use the SP (r1). I've
single-stepped through the assembly and see that r1 and r31 have the
same value. Also r31 is not the 'this' pointer, it is passed into the
function in r3 and then saved on the stack. Maybe my function example is
too trivial.
I can see that turning on optimization might get rid of a lot of the
stack manipulations with all the registers available on PPC.
BTW I have a copy of the IBM PPC EABI and it says the stack frame is
"...always doubleword aligned (on 8 byte boundaries) by using padding".
Just curious where you got the number or 16 bytes for your padding?
Could you forward me a reference to your ELF ABI
robert
From: Neil Schellenberger [mailto:community-noreply@qnx.com]
Sent: Thursday, March 26, 2009 5:51 PM
To: general-toolchain
Subject: Re: Deciphering Function prologue and epilogue for PPC-based
code
Hi Robert,
38: 4e 80 00 20 blr
Neil
> Hi:
setting up and unwinding the stack. The code is c++ and compiled under
PPC EABI docs is that R1 is treated as the stack pointer. The steps for
for the new frame, save the old SP in this frame (the back chain
pointer) and also save the return address (Link Register) in the slot in
saving/restoring register R31 which appears to be operating as a frame
pointing to the same thing. So my questions:
actually used for storing frame header + parameters + local vars?
> m_dir = value;
> 4804061c: 81...
03/27/2009 5:22 PM
post25487
Hi Robert,
I imagine that the use of r31 in the unoptimized code is simply a case
of "it's already inefficient, so let's make things easy on ourselves".
The Sun PPC ABI (which I believe is the relevant one here) requires that
"Languages that require "environment pointers" shall use r31 for that
purpose." (3-15) It also stipulates "The stack pointer shall maintain
16-byte alignment." (3-17). As you correctly point out, the C++ "this"
pointer is treated as a hidden first argument and, therefore, is always
passed in r3.
As QNX is not the copyright holder of the ABI document, I am not sure
that I can publish it for you here. The full title is "SYSTEM V
APPLICATION BINARY INTERFACE PowerPC Processor Supplement" and is easily
located online through Google.
Caveat lector! There are (at least) two documents which are known as
the PPC EABI. One is the Embedded ABI (which does stipulate doubleword
padding); the other is the ELF ABI, which is the one you want ;-)
Neil
On Fri, 2009-03-27 at 17:09 -0400, Robert D'Attilio wrote:
> Neil & Aleksander:
> too trivial.
> Thanks
> robert
> code
> Hi Robert,
> 38: 4e 80 00 20 blr
> Regards,
> Neil
> > Hi:
> PPC EABI docs is that R1 is treated as the stack...
03/30/2009 4:23 PM
post25607
Neil:
Thanks for the insight and reference. I have both docs but was focusing
on the Embedded ABI for my information.
Cheers
robert
Sent: Friday, March 27, 2009 5:23 PM
Subject: RE: Deciphering Function prologue and epilogue for PPC-based
code
Hi Robert,
passed in r3.
Neil
> Neil & Aleksander:
see
is
> too trivial.
padding".
> Thanks
> robert
> code
> Hi Robert,
unoptimized
> 38: 4e 80 00 20 blr
> Regards,
> Neil
> On...
03/30/2009 4:46 PM
post25615
Hi Robert,
Glad that helped. There are a wide variety of -m flags to the compiler
to force the Embedded API and related magic (e.g. -meabi), but that road
almost certainly leads to madness ;-) It definitely leads to needing to
recompile virtually everything yourself, probably including the kernel.
And even then, I'm not too certain it would work out of the gate....
Neil
On Mon, 2009-03-30 at 16:23 -0400, Robert D'Attilio wrote:
> Neil:
> Cheers
> robert
> code
> Hi Robert,
> passed in r3.
> Regards,
> Neil
> > Neil & Aleksander:
> see
> is
> > too trivial.
> padding".
> > Thanks
> > robert
> > code
> > Hi Robert,
> unoptimized
> > 4.2.4 at O2, you'd get...
Re: RE: Deciphering Function prologue and epilogue for PPC-based code
03/29/2009 1:28 PM
post25502
> Neil & Aleksander:
> too trivial.
I didn't say "this" was passed in r31, what I saw was "this" being loaded into r31 at some point in the method itself...
but I did not really go any deeper to understand why. (my sample function involved calling a method of a member object,
so I imagine it is a part of calculation of the member's address).
Aleksandar
03/31/2009 9:56 AM
post25646
Btw if you trying to get backtrace we have a library that does that.
> Hi:
my questions:
+ local vars?
> m_dir = value;
> Test* p = this;
> Thanks
> robert
03/31/2009 10:16 AM
post25652
Interesting, what is it called?
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Tuesday, March 31, 2009 9:56 AM
code
> Hi:
> m_dir = value;
> Test* p = this;
> Thanks
> robert
General
http://community.qnx.com/sf/go/post25646
03/31/2009 10:19 AM
post25653
/opt/qnx641/target/qnx6/ppcbe/usr/lib/libbacktrace.[a/so/so.1]
Let me find the docs...
03/31/2009 10:44 AM
post25662
Here's a zip file that includes a technote about libbacktrace, as well as reference pages for the functions. These will
be part of the documentation in QNX SDP 6.4.1.
A couple of things to note:
- The links from the technote to the reference pages won't work because they normally live in separate books.
- The library is unsupported because it's somewhat fragile.
I hope this helps; if you have any comments about these docs, please post them here.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
03/31/2009 10:57 AM
post25671
Steve/Elena:
Thanks a bunch for the tip and docs.
I gather this is only available in 6.4.1 and not 6.3.2?
Robert
From: Steve Reid [mailto:community-noreply@qnx.com]
Sent: Tuesday, March 31, 2009 10:44 AM
code
as reference pages for the functions. These will be part of the
post them here.
Technical Editor
General
http://community.qnx.com/sf/go/post25662
03/31/2009 11:00 AM
post25672
6.4.0 also, If you really need I can build it for 6.3.2 as unsupported
> Steve/Elena:
> Robert
> code
> post them here.
> Technical Editor
> http://community.qnx.com/sf/go/post25671
03/31/2009 11:12 AM
post25676
Elena:
That would be great if you could as we won't be moving to 6.4 for
another while.
robert
Sent: Tuesday, March 31, 2009 11:00 AM
code
> Steve/Elena:
> Robert
> code
because
> post them here.
> Technical Editor
General
http://community.qnx.com/sf/go/post25672
03/31/2009 11:18 AM
post25679
try attached (pick variant you need). Technically it is open source so you can compile it yourself next time
or use source for reference.
RE: RE: Deciphering Function prologue and epilogue for PPC-based code
04/02/2009 9:23 AM
post25838
Thanks!
Sent: Tuesday, March 31, 2009 11:19 AM
Subject: Re: RE: Deciphering Function prologue and epilogue for
PPC-based code
General
http://community.qnx.com/sf/go/post25679
