Forum Topic - Gcc 4.3/4.4: (11 Items)
Gcc 4.3/4.4
Are you planning gcc 4.3 or gcc 4.4 in Foundry27 ?
Re: Gcc 4.3/4.4
Yes, we will be posting gcc 4.3.3 packages on the Foundry in the very
near future.
Ryan Mansfield
Re: Gcc 4.3/4.4
OK
[core-dev-tools] / tools / gcc / trunk  now is gcc4.3.3
build-hooks :
is
configure_opts="${configure_opts} --with-gxx-include-dir=${qnxtarget}/usr/include/c++/$gcc_version"
correct for SYSNAME=nto and target=*nto-qnx* ?
On my system QNX 6.4.1
case ${target} in
	*nto-qnx*)
		configure_opts="${configure_opts} --enable-cheaders=c"
		configure_opts="${configure_opts} --with-as=${nto_target}-as-2.19"
		configure_opts="${configure_opts} --with-ld=${nto_target}-ld-2.19"
	esac
not work. When I remove
it's working
Re: Gcc 4.3/4.4
bogdan celer wrote:
> OK
> build-hooks :
> is
If you're building under the version of nto that you're targeting, you
can change ${qnxtarget} to $QNX_TARGET. Currently the build-hooks
assume you're building under Momentics 640. I will make change the build
  -hooks so build triplets are easier to set/configure.
> case ${target} in
> 	*nto-qnx*)
> 	esac
> it's working
At what point of the build does it fail?
Ryan Mansfield
Re: Gcc 4.3/4.4
Sorry, but I forgot to say that the problem has the place only when I compiling gcc4.4.0 and 4.5.0
I use the same build-hooks for all gcc:
# diff build-hooks(4.4.0) build-hooks(4.3.3)
84,85c84,85
<       #       configure_opts="${configure_opts} --with-as=${nto_target}-as-2.19"
<       #       configure_opts="${configure_opts} --with-ld=${nto_target}-ld-2.19"
90d89
<       configure_opts="${configure_opts} --program-suffix=-4.4.0"
100c99
<       configure_opts="${configure_opts} --enable-languages=c,c++,ada,fortran,objc"
>       configure_opts="${configure_opts} --enable-languages=ada"
Press any key to continue...
============ gcc 4.4.0 ===============
make -j 1 -Cnto-x86-o-ntox86 -fGNUmakefile
make[1]: Entering directory `/src/gcc-4.4.0/nto-x86-o-ntox86'
AR_HOST=' /usr/qnx641/host/qnx6/x86/usr/bin/cc -a' AS_HOST=' /usr/qnx641/host/qnx6/x86/usr/bin/cc -c'....
hook_preconfigure: /usr/qnx641/target/qnx6/usr/include/mk/build-cfg[349]: [: -lt: missing second argument
hook_preconfigure: /usr/qnx641/target/qnx6/usr/include/mk/build-cfg[349]: [: -gt: missing second argument
checking build system type... i386-pc-nto-qnx6.4.1
checking host system type... i386-pc-nto-qnx6.4.1
checking target system type... i386-pc-nto-qnx6.4.0
checking whether we are using the GNU C++ compiler... yes
checking whether i386-pc-nto-qnx6.4.0-g++ accepts -g... yes
checking for gnatbind... gnatbind
checking for gnatmake... gnatmake
checking whether compiler driver understands Ada... yes
checking for correct version of gmp.h... yes
checking for correct version of mpfr.h... yes
checking for version 0.10 of PPL... yes
checking for correct version of CLooG... no
The following languages will be built: c,ada
mkdir ./gcc
Configuring in ./gcc
configure: creating cache ./config.cache
checking LIBRARY_PATH variable... ok
checking GCC_EXEC_PREFIX variable... ok
checking whether to place generated files in the source directory... no
configure: error: cannot execute: ntox86-ld-2.19: check --with-ld or env. var. DEFAULT_LINKER
make[3]: *** [configure-gcc] Error 1
make[3]: Leaving directory `/src/gcc-4.4.0/nto-x86-o-ntox86'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/src/gcc-4.4.0/nto-x86-o-ntox86'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/src/gcc-4.4.0/nto-x86-o-ntox86'
make: *** [all] Error 2
================= gcc 4.3.3 =============
mkdir ./gcc
checking whether a default linker was specified... yes (ntox86-ld-2.19 - GNU ld)
checking whether a default assembler was specified... yes (ntox86-as-2.19 - GNU as)
checking for i386-pc-nto-qnx6.4.1-gcc... i386-pc-nto-qnx6.4.0-gcc
Has someone some hints why this has the place ?
bogdan
Re: Gcc 4.3/4.4
We have non-standard modifications to configure, gcc.c and collect2.c
and a few other places to support the $QNX_HOST/$QNX_TARGET environment
variables. The search order of the default assembler and linker are one
of those modifications. IIRC, you can specify an absolute path to
with-as/with-ld and avoid this problem but your gcc will not be
completely relocatable as the driver will launch with assembler/linker
with the full path.
You could try:
--with-as=$QNX_HOST/usr/bin/${nto_target}-as-2.19"
--with-ld=$QNX_HOST/usr/bin/${nto_target}-ld-2.19"
Ryan Mansfield
Re: Gcc 4.3/4.4
> You could try:
> Regards,
> Ryan Mansfield
Ryan thank you. It work well with gcc4.4.
Re: Gcc 4.3/4.4
It looks to me like the build-hooks on trunk is buggy.  You can try
adding
  minimum_binutils=2.19
at the start, but there may be other problems (I haven't actually tried
it).
> 84,85c84,85
> 90d89
> 100c99
> mkdir ./gcc
> mkdir ./gcc
> checking whether to place...
Re: Gcc 4.3/4.4
I've raised PR 67849 to track this (if it is indeed a bug rather than a deprecated feature - Ryan?)
Re: Gcc 4.3/4.4
The minimum binutils gear at the bottom is legacy cruff we don't really
need anymore. It sneaked back in when I was doing the 4.2.4-4.3.3 merge.
Ryan Mansfield
Re: Gcc 4.3/4.4
It kind of looked like that was the case, but I wasn't certain.  Should
be an easy PR ;-)
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post28208
