Forum Topic - Linking GCC compiled library with QNX 6.4.0 tools: (5 Items)
I have a library generated with "arm-none-linux-gnueabi-gcc-4.1.2" tools. I want to link this with QNX tools. I am
gettign errors like EABI version conflict.
Can I link GCC library like this?
D:/projects/h264dec/test/arm\libh264dec.a(nalucommon.o) has EABI version 4, but target C:/ide-4.5-workspace/h264dec/arm/
o-le/h264dec has EABI version 0
Venkat
Re: Linking GCC compiled library with QNX 6.4.0 tools
Venkatarao Patnaik Balivada wrote:
No, the QNX toolchain uses the apcs-gnu ABI and does not follow the EABI
. The two ABIs are incompatible so you will have to rebuild your library.
Ryan Mansfield
Can I rebuild the library with GCC tools with some options to make it compatible? OR I need to rebuild the library with
QNX tools?
with QNX tools?
It should be possible to generate apcs-gnu code from your linux
toolchain using -mabi=apcs-gnu. However, your toolchain has likely been
configured only for aapcs-linux which means the libgcc and other target
libraries will follow the EABI, and you will not be able to link  your
library.
I strongly recommend using the QNX gcc toolchain to rebuild your library.
Ryan Mansfield
Okay. Thanks Ryan
