Problem debugging stack variables in constructor
03/14/2009 11:35 AM
post24374
I'm having problems debugging a constructor of a class.
When I start with main() I can see the stack variables in main. When I step into the class constructor (not the default
constructor) I see the passed arguments to the constructor, and the member variables, but no local stack variables
appear in the 'Variables' view for the constructor.
When I hover over any of the stack variables I get the error:
No symbol "xxx" in current context.
All source files are all part of the same executable and are all in the same directory.
In the 'verbose' gdb console output I see the following:
^error,msg="A syntax error in expression, near `'."
I see the following potential problem in the gdb console output,
at
ptype this
The prototype of the class is listed properly, with the exception of two functions. The return arg is shown as
._40 & FuncA(int);\n
._40 & FuncB(int);\n
where '._40' appears should be a local typedef. All other function return types are Plain Old Data (int, void, etc.)
[this seems to be normal behavior as I see this ._xx syntax in other function prototypes in other classes in gdb]
There are no compiler errors or warnings for this code.
I am using QNX 6.4.0 running in a VMWare 2.0 session. I using Windows XP and IDE 4.6.
I don't have this problem with other classes.
Any hints where to look for the problem?
