Re: Reading the debug information
03/11/2009 1:42 PM
post24167
Most realistic way is using debugger. If you are interested
in observing the values at particular point in your program,
you set your breakpoint there and when stopped, you can
examine your variables in the debugger. If you want to find
where exactly is each of the variables changed, you can set
watchpoints on those variables which will cause debugger to
stop at instruction that modifies them.
To monitor all this from remote machine, we support remote
debugging where on your target you run our debugging agent
called pdebug (or if you are using IDE, qconn). Then from
your host (for example windows) you can comfortably debug
your application that is running on qnx machine. You can use
debugger from command line, or using IDE.
If you are not familiar with gdb (debugger), I suggest using
IDE.
Hope this helps,
Aleksandar
Elena Laskavaia wrote:
> I know how to do in IDE, if you running debugger. You add all global variables in the variables view (this list is
retrieved from binary symbol table).
> When you can stop program and inspect the values. You can set watchpoint on them if you interested in when somebody
changes them.
> Sushma Nayak wrote:
>> Hi all,
>> I am really new to the QNX environment.
>> I want to be able to monitor all the global variables in my application
>> running on qnx at runtime. There would be another client application
>> running on another machine which would receive the values of the global
>> variables over UDP and display them.
>> I would like to know where all the information regarding a global
>> variable is stored (type of the variable, its address etc).
>> In Windows (Visual Studio) all this information is stored in a .pdb
>> file. Is there a similar file generated if I compile my application on
>> qnx?
>> Thanks,
>> Sushma
>> General
>> http://community.qnx.com/sf/go/post24152
> http://community.qnx.com/sf/go/post24156
