03/04/2009 12:22 PM
post23496
I'm trying to understand what this option (-Wc,-mno-fp-moves) does. But I can't for the life of me find any
documentation anywhere - either on qnx.com (http://www.qnx.com/developers/docs/6.3.2/neutrino/utilities/q/qcc.html)
or gnu.org.
I understand that -m is an emulation option.
I'm trying to ensure that floating point emulation does NOT occur. Here is my complete command string:
C:/QNX632/host/win32/x86/usr/bin/qcc
-Vgcc_ntoppc
-c
-O
-Wc,-mno-fp-moves
-Wc,-Wall
-Wc,-Wno-parentheses
-DNDEBUG
-I.
-Ic:/data/qnx_ppc_bsp1/src/apps/fpu_test/ppc/be
-IC:/QNX632/target/qnx6/usr/include/xilinx
-EB
-DVARIANT_be
c:/data/qnx_ppc_bsp1/src/apps/fpu_test/main.c
Also, what is the purpose of the options
-DNDEBUG & -DVARIANT_BE
Re: -Wc,-mno-fp-moves option
03/04/2009 2:49 PM
post23524
One of the compiler guys might be able to give more background, but I'll
take a stab at answering this.
The flag is a QNX-specific addition to gcc. It prevents the code
generator from using floating point registers for integer moves. (I
think that the code generator does this to reduce register pressure. We
try to avoid it because it may force an FP context switch, which is even
more expensive than the original problem :-)
So, long story short, the -mfp-no-moves flag has no real bearing on
floating point code, per se.
On Wed, 2009-03-04 at 12:22 -0500, Matt Ferraro wrote:
> Hello,
> or gnu.org.
> -Vgcc_ntoppc
> -c
> -O
> -Wc,-mno-fp-moves
> -Wc,-Wall
> -DNDEBUG
> -I.
> -EB
> -DVARIANT_be
> http://community.qnx.com/sf/go/post23496
03/04/2009 2:57 PM
post23528
Back at the time it -mno-fp-moves was implemented, the compiler was deciding to place things like PhRect_t in floating
point registers - it could then do a single 64bit floating point move, to assign them around.
However as you can imagine, this was causing serious slowdowns on powerpc machines that used fpu emulation, so we
made the compiler an offer it couldn't refuse.
>> Hello,
>> or gnu.org.
>> -Vgcc_ntoppc
>> -c
>> -O
>> -Wc,-mno-fp-moves
>> -Wc,-Wall
>> -DNDEBUG
>> -I.
>> -EB
>> -DVARIANT_be
>> General
> http://community.qnx.com/sf/go/post23524
cburgess@qnx.com
RE: -Wc,-mno-fp-moves option
03/04/2009 3:02 PM
post23530
Sounds like something to add to the docs. I'll create a PR.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Re: RE: -Wc,-mno-fp-moves option
04/23/2009 6:33 AM
post27849
Interesting! Also sounds like something that could go away in 1-2 years, when non-FPU PPCs disappear. AFAIK the only PPC
without FPU is the 405.
At least I'm a small step further now in my ever-lasting quest to find out why QNX 4.25 Photon seems a bit faster than
QNX Neutrino's. :-)
- Malte
04/23/2009 1:52 PM
post27922
For Neutrino there are actually potentially negative performance
implications for doing this on a hardware FPU. Since we spill the FPU
context in a lazy fashion, it is entirely possible that executing an FPU
instruction will require the context to be reloaded.
PPC without FPU is the 405.
QNX Neutrino's. :-)
> - Malte
> http://community.qnx.com/sf/go/post27849
04/24/2009 5:23 AM
post27964
Hey Neil,
can you elaborate on this? What does it mean - spill FPU context in a lazy fashion, and reload context?
This is very interesting because I'm trying to find out what's going on regarding PR 67633.
Are you saying the using FPU opcodes causes... what. Exceptions?
- Malte
04/24/2009 1:29 PM
post28038
Hi Malte,
The FPU context is only saved (spilled) when an FPU instruction is
executed from a thread which is different from the last thread to use
the FPU on that CPU. (This is called "lazy" since it defers the spill
until the very last possible moment.) This can potentially greatly slow
down this particular optimization (using FP registers for 64 bit integer
moves).
Neil
On Fri, 2009-04-24 at 05:23 -0400, Malte Mundt wrote:
> Hey Neil,
> - Malte
> http://community.qnx.com/sf/go/post27964
04/28/2009 5:57 AM
post28220
Ah, this means it gets saved in the moment when a different thread is using the FPU, which in turn means that this
particular optimization would be much slower. Correct?
But how does the kernel (I assume it's the kernel that does the saving of the FPU context) know that a different thread
is executing FPU instructions? Is the kernel invoked every time an FPU instruction is used? Or does the kernel somehow
program the CPU to generate an exception the first time a different thread is using the FPU?
- Malte
04/28/2009 7:32 AM
post28223
The kernel keeps a state variable (per-cpu) in actives_fpu[] that records
which thread currently "owns" the FPU.
In essence the following actions are performed for the lazy context switch:
Initially the FPU is disabled so the first FPU instruction causes a trap.
The kernel allocates an FPU save area and initialises it with default values.
Because actives_fpu[RUNCPU] is NULL and the thread has an allocated FPU save
area we load the FPU registers, set actives_fpu[RUNCPU] to the this thread
and restart the FPU operation.
If a thread context switch occurs, actives_fpu[RUNCPU] remains unchanged,
but the kernel disables the FPU because actives_fpu[RUNCPU] is different to
the currently active thread:
- if the new thread does no FPU operations, everything is fine.
If we subsequently switch back to the original thread, the FPU is still
disabled so we trap, but since actives_fpu[RUNCPU] indicates the thread
owns the FPU, we can simply re-enable the FPU and restart the instruction.
- if the new thread does an FPU operation, we trap and allocate an FPU save
area for it and initialise it with default values.
Since actives_fpu[RUNCPU] is non-NULL, we save the FPU register context in
that save area, then load the FPU registers from the new thread's save area.
We set actives_fpu[RUNCPU] to the new thread, re-enable the FPU and restart
the instruction.
This means we'll incur at least the cost of an FPU-disabled exception whenever
we context switch back to a thread that is actively using the FPU, and will
incur the additional cost of an FPU register save and re-load if we repeatedly
switch between threads that are actively using the FPU.
This state machine is implemented in the cpu-specific code, involving the
relevant trap handlers in kernel.s to detect the various FPU exceptions based
on the FPU enable/disable state and actives_fpu[RUNCPU].
Sunil.
thread is executing FPU instructions? Is the kernel invoked every time an FPU instruction is used? Or does the kernel
somehow program the CPU to generate an exception the first time a different thread is using the FPU?
> - Malte
> http://community.qnx.com/sf/go/post28220
05/07/2009 8:07 AM
post28878
Sunil, this is an excellent explanation! Thanks a lot man!!
- Malte
