Forum Topic - GDB (on PPC target) can't step into functions derived from abstract class:
Hi:
I'm experiencing a problem with gdb when trying to step into functions of a class that are derived from an abstract base
 class. I've been able to reproduce the problem on a simple example which I've included below:
#include <stdio.h>
class Base
public:
  virtual void hello();
  virtual void run()=0;
class Derived : public Base
public:
    void run();
void Base::hello(){printf("Base::Hello()\n");}
void Derived::run(){printf("Dervied::Run\n");}
int main (int argc, char *argv[])
    Base* pBase = new Derived();
    pBase->hello();
    pBase->run();
    return 0;
If I try to step into the calls to pBase->hello() or pBase->run(), the debugger ends up in some QNX library code
(MsgSendv() 0xfe339f64) but never reaches my implementation (the printf calls). However, I can set  breakpoints within
the hello() or run() methods and the debugger will stop on them.
Here are the relevant build and target details:
QNX 6.3.2
qcc: 3.3.5 - building with -g and no optimization
gdb: 6.7 (5.2.1)
target: PPC405EP
host: linux
IDE: 4.5 - Note: I normally debug from the IDE but I was able to reproduce the behaviour by just running gdb directly.
I dug a little further looking at the assembly and single-stepping through that and the problem seems to be related to
the bctrl branch instruction which the debugger can't seem to be able to follow. Both function calls use the bctrl for
their branching. Here is the corresponding assembly for the call to hello()
48040714:	81 3f 00 10 	lwz	r9,16(r31)
48040718:	81 29 00 00 	lwz	r9,0(r9)
4804071c:	81 29 00 00 	lwz	r9,0(r9)
48040720:	7d 29 03 a6 	mtctr	r9
48040724:	80 7f 00 10 	lwz	r3,16(r31)
48040728:	4e 80 04 21 	bctrl
Examination of the ctr register shows that it has the correct address for the start of the hello() method. Now if I make
 all the methods non-virtual and adjust the instantiation accordingly, all the branches change from bctrl to bl and the
debugger is now able to step into the functions. I suspect the mtctr/bctrl constructs have to do with managing the
vtables?
Anyone else seen this behaviour or have an explanation or solution for why gdb can't follow the trail?
Robert
Re: GDB (on PPC target) can't step into functions derived from abstract class
Robert D'Attilio wrote:
> Hi:
base class. I've been able to reproduce the problem on a simple example which I've included below:
> #include <stdio.h>
> class Base
> public:
> public:
>     void run();
>     pBase->hello();
>     pBase->run();
>     return 0;
> QNX 6.3.2
> gdb: 6.7 (5.2.1)
Does this mean you tried with both gdb-6.7 and gdb-5.2.1?
Aleksandar
RE: GDB (on PPC target) can't step into functions derived from abstract class
Yes that is correct: I tried this on both gdb 6.7 and 5.2.1. Sorry for
the confusion.
Robert
From: Aleksandar Ristovski [mailto:community-noreply@qnx.com]
Sent: Thursday, February 19, 2009 11:56 AM
To: general-toolchain
Subject: Re: GDB (on PPC target) can't step into functions derived from
abstract class
> Hi:
of a class that are derived from an abstract base class. I've been able
> #include <stdio.h>
> class Base
> public:
> public:
>     void run();
>     pBase->hello();
>     pBase->run();
>     return 0;
debugger ends up in some QNX library code (MsgSendv() 0xfe339f64) but
breakpoints within the hello() or run() methods and the debugger will
stop on them.
> QNX 6.3.2
> gdb: 6.7 (5.2.1)
Aleksandar
General
http://community.qnx.com/sf/go/post22540
I just tried and it worked for me.
Could you do a
(gdb) show version
in your 6.7 gdb and post it here?
Also, could you do the following on your binary (and post
the output):
# ntoppc-readelf -wi <your binary> | grep DW_AT_producer
Aleksandar
Aleksandar:
Here is the info:
show version
GNU gdb 6.7 qnx-nto update 10 (rev. 254)
Copyright (C) 2007 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show
copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu
--target=powerpc-unknown-nto-qnx6.3.0".
robert@WrBuildServer3: o-be $ ntoppc-readelf -wi TestPro | grep
W_AT_producer
     DW_AT_producer    : GNU C++ 3.3.5 (qnx-nto)
I'm curious to see the disassembly of what you compiled to see how it
compares with mine. Are your function calls invoked via bctrl machine
instruction?
Sent: Thursday, February 19, 2009 12:38 PM
abstract class
Could you do a
(gdb) show version
the output):
Aleksandar
General
http://community.qnx.com/sf/go/post22546
> instruction?
It looks like it is. I attached the binary to this reply.
================= disassembly =====================
480407dc <main>:
480407dc:       94 21 ff d0     stwu    r1,-48(r1)
480407e0:       7c 08 02 a6     mflr    r0
480407e4:       93 a1 00 24     stw     r29,36(r1)
480407e8:       93 e1 00 2c     stw     r31,44(r1)
480407ec:       90 01 00 34     stw     r0,52(r1)
480407f0:       7c 3f 0b 78     mr      r31,r1
480407f4:       90 7f 00 08     stw     r3,8(r31)
480407f8:       90 9f 00 0c     stw     r4,12(r31)
480407fc:       38 60 00 04     li      r3,4
48040800:       48 00 14 69     bl      48041c68 <_Znwj@plt>
48040804:       7c 7d 1b 78     mr      r29,r3
48040808:       7f a3 eb 78     mr      r3,r29
4804080c:       48 00 00 fd     bl      48040908
<_ZN7DerivedC1Ev>
48040810:       7f a0 eb 78     mr      r0,r29
48040814:       90 1f 00 10     stw     r0,16(r31)
48040818:       81 3f 00 10     lwz     r9,16(r31)
4804081c:       81 29 00 00     lwz     r9,0(r9)
48040820:       81 29 00 00     lwz     r9,0(r9)
48040824:       7d 29 03 a6     mtctr   r9
48040828:       80 7f 00 10     lwz     r3,16(r31)
4804082c:       4e 80 04 21     bctrl
48040830:       81 3f 00 10     lwz     r9,16(r31)
48040834:       81 29 00 00     lwz     r9,0(r9)
48040838:       39 29 00 04     addi    r9,r9,4
4804083c:       81 29 00 00     lwz     r9,0(r9)
48040840:       7d 29 03 a6     mtctr   r9
48040844:       80 7f 00 10     lwz     r3,16(r31)
48040848:       4e 80 04 21     bctrl
4804084c:       38 00 00 00     li      r0,0
48040850:       7c 03 03 78     mr      r3,r0
48040854:       81 61 00 00     lwz     r11,0(r1)
48040858:       80 0b 00 04     lwz     r0,4(r11)
4804085c:       7c 08 03 a6     mtlr    r0
48040860:       83 ab ff f4     lwz     r29,-12(r11)
48040864:       83 eb ff fc     lwz     r31,-4(r11)
48040868:       7d 61 5b 78     mr      r1,r11
4804086c:       4e 80 00 20     blr
============== gdb session: ==============================
$ gdbu10/host/linux/x86/usr/bin/ntoppc-gdb $EXE --ex "target
qnx 10.42.122.79:8000" --ex "upload $EXE /tmp/derived"
redistribute it.
"show copying"
--target=powerpc-unknown-nto-qnx6.3.0"...
Remote debugging using 10.42.122.79:8000
MsgNak received - resending
Remote target is big-endian
(gdb) start
Temporary breakpoint 1 at 0x480407fc: file
/home/src/testcases/derivedcpp/derived.cpp, line 21.
Starting program: /mnt/win/derivedcppppcbe632-3.3.5
Remote: /tmp/derived
advancSetting Dynamic-Linker Breakpoint based on
/opt/qnx/target/qnx6//ppcbe/usr/lib/ldqnx.so.2
e warning: Host file
/opt/qnx640/target/qnx6/ppcbe/lib/libc.so.3 does not match
target file.
22
Temporary breakpoint 1, main (argc=1, argv=0x4803ff14)
     at /home/src/testcases/derivedcpp/derived.cpp:21
21          Base* pBase = new Derived();
(gdb) advance 22
main (argc=1, argv=0x4803ff14) at
/home/src/testcases/derivedcpp/derived.cpp:22
22          pBase->hello();
(gdb) step
Base::hello (this=0x4804a2d8) at
/home/src/testcases/derivedcpp/derived.cpp:16
16      void Base::hello(){printf("Base::Hello()\n");}
(gdb) n
Base::Hello()
/home/src/testcases/derivedcpp/derived.cpp:23
23          pBase->run();
(gdb) show version
Copyright (C) 2007 Free Software...
Attachment: Text derivedcppppcbe632-3.3.5.gz 5.13 KB
I tried launching your binary on my system (although I had to explicitly
download a different libcpp.so as we use the "Dinkum Abridged without
Exceptions" version - as an aside, I thought this (the different libcpp)
might be the problem but it wasn't). I stepped through the disassembly
and end up with the same behaviour as with my binary. Here is a stack
trace (of your binary) immediately after I try to step into hello().
#0  0xfe339f64 in MsgSendv () from
/opt/qnx632/target/qnx6/ppcbe/lib/libc.so.2
#1  0xfe35f14c in _devctl () from
#2  0xfe318f18 in isatty () from
#3  0xfe34dd50 in _Fbuf () from
#4  0xfe34e48c in _Fwprep () from
#5  0xfe34c0ec in fwrite () from
#6  0xfe34dfb8 in _Fprout () from
#7  0xfe351478 in _Printf () from
#8  0xfe34c690 in printf () from
#9  0x48040784 in Base::hello (this=0x48044330) at
#10 0x48040830 in main (argc=1, argv=0x4803fe74) at
It almost seems as if we're jumping directly into the printf() function
call from within hello(). On a hunch, I've tried inserting additional
'C' statements before the printf() statement in hello() but it doesn't
help.
I'm running out of ideas...can I see the output of your build command
(compile and link options) to compare it with mine?
robert
Sent: Thursday, February 19, 2009 1:46 PM
abstract class
> instruction?
480407dc <main>:
<_ZN7DerivedC1Ev>
48040860:       83 ab ff f4     lwz   ...
you stepped through disassembly with 'stepi', or just did
step again once you stopped in Base::hello (or run)? If you
could, post exact commands you issued to gdb before you got
to this point.
> help.
Do you see any warnings about mismatched libraries at the
beginning of debugging session (do a 'start' at the
beginning, it will run to main and stop there. There will be
message about libc.so.2 and warnings if any).
Be aware that I run the binary on a 6.4.0 system. It might
have something to do with it - I will have to try it on a
6.3.2 system (working on it).
$ QNX_TARGET=/opt/qnx632/target/qnx6/
QNX_HOST=/opt/qnx632/host/linux/x86/ make CCOPTS=-v
LDOPTS=-v GCC_VERSION=3.3.5
/opt/qnx632/host/linux/x86//usr/bin/qcc -V3.3.5,gcc_ntoppc
-c  -Wc,-mno-fp-moves -Wc,-Wall -Wc,-Wno-parentheses
        -I. -I/home/src/testcases/derivedcpp/nto/ppc/be
-I/home/src/testcases/derivedcpp/nto/ppc/o-be-g
-I/opt/qnx632/target/qnx6/usr/include    -EB  -g
-DVARIANT_be -DVARIANT_g -v
cc: looking for gcc_ntoppcbe+debug in
/opt/qnx632/host/linux/x86//etc/qcc/gcc/3.3.5/gcc_ntoppcbe++.conf
/opt/qnx632/host/linux/x86//etc/qcc/gcc/3.3.5/gcc_ntoppcbe.conf
/opt/qnx632/host/linux/x86//usr/lib/gcc-lib/powerpc-unknown-nto-qnx6.3.0/3.3.5/cc1plus
-I/opt/qnx632/target/qnx6/usr/include -g2 -DVARIANT_be
-DVARIANT_g -quiet -fno-builtin -mno-fp-moves -nostdinc
-nostdinc++ -D__cplusplus -D__QNX__ -D__QNXNTO__
-D__GNUC__=3 -D__GNUC_MINOR__=3 -D__GNUC_PATCHLEVEL__=5
-D__GNUG__=3 -D__GXX_ABI_VERSION=102 -D__NO_INLINE__
-D__DEPRECATED -D__EXCEPTIONS -D__unix__ -D__unix -D__ELF__
-D__PPC -D_ARCH_PPC -D_CALL_SYSV...
Here is a trace of what I am doing. Note I am debugging from the IDE and
typically use the 'step over' and 'step into' buttons but to illustrate
what I am doing I have entered the following commands manaully on the
gdb console in the IDE:
When the excutable launches it stops at the line:
I use the 'next' command to step over to the next source line
	pBase->hello();
next
next
22	    pBase->hello();
Then I use a series of 'stepi' commands to execute the machine
instructions to 'step into' the function hello().
stepi
stepi
0x4804081c	22	    pBase->hello();
stepi
stepi
0x48040820	22	    pBase->hello();
stepi
stepi
0x48040824	22	    pBase->hello();
stepi
stepi
0x48040828	22	    pBase->hello();
stepi
stepi
0x4804082c	22	    pBase->hello();
stepi
stepi
Here is the disassembly for the above:
    pBase->hello();
One interesting point, if before doing the stepi instructions above, I
insert a breakpoint on the printf() statement in hello(), the stepi
instructions will successfully step into the hello() function and halt
on the printf() function call.
Sent: Thursday, February 19, 2009 4:18 PM
abstract class
explicitly
libcpp)
to this point.
function
> help.
have something to do...
> 	pBase->hello();
> next
> next
> 22	    pBase->hello();
Note that 'stepi' command means "step one instruction" while
"step" means step into the function. If you use "step" -
does it still behave this way?
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
> stepi
>     pBase->hello();
in this case I think you did equivalent of
(gdb) b 'Base::hello()'
This is normal.
Yes it still behaves the same way.
Sent: Thursday, February 19, 2009 5:16 PM
abstract class
and
illustrate
> 	pBase->hello();
> next
> next
> 22	    pBase->hello();
Robert,
I just run the test on a 6.3.2 ppc target and it still works
fine for me.
# uname -a
QNX t2ppcbe 6.3.2 2006/03/16-14:19:24EST 8555CDS ppcbe
Please make sure you are not getting any warnings about
mismatched libraries.
Aleksandar
Aleksandar:
As far as I can tell I'm not getting any mismatched library warnings
from either the build process or when launching from gdb. Is there
anywhere else I should look for these warnings?
Here is the result from my uname
# uname -a
QNX localhost 6.3.2 2006/03/16-14:18:11EST WRM_782 ppcbe
robert
Sent: Thursday, February 19, 2009 4:34 PM
abstract class
Robert,
fine for me.
# uname -a
Aleksandar
General
http://community.qnx.com/sf/go/post22565
> Aleksandar:
If you start gdb from console, you will see it. I think it
should be visible in the ide console as well, but it may
depend on the ide version... not sure.
Try starting gdb from your shell (you can see the command
line I used).
Aleksandar:
I tried starting gdb from the shell and don't see any warnings or errors
regarding libraries. Here is what I see:
(gdb) run
Starting program:
/home/robert/ide-4.5-workspace-782/TestBed/ppc/o-be-g/TestBed_g
Remote: /tmp/TestBed_g2
/opt/qnx632/target/qnx6/ppcbe/usr/lib/ldqnx.so.2
Breakpoint 1, main (argc=1, argv=0x4803fed4)
    at /home/robert/ide-4.5-workspace-782/TestBed/TestBed.cc:25
25          Base* pBase = new Derived();
Sent: Thursday, February 19, 2009 5:11 PM
abstract class
> Aleksandar:
line I used).
General
http://community.qnx.com/sf/go/post22570
> Aleksandar:
> (gdb) run
> Starting program:
Ok, then that part is ok.
The only way I can try to diagnose (since I can not
reproduce it locally) is if you do the following:
1) On your target, in your shell set PDEBUG_DEBUG env. variable:
# export PDEBUG_DEBUG=1
2) Start pdebug on your target but tell it to use port other
than 8000, and redirect the output into a file:
# pdebug -v 8010 > /tmp/pdebug.log 2>&1
(-v is for vrebose)
3) On your host, start gdb from your shell:
$ ntoppc-gdb <your binary on linux> --ex "target qnx <your
target hostname>:8010" --ex "upload <your binary on linux>
/tmp/test"
4) Do this simple debug session:
(gdb) set logging file /tmp/gdb.log
(gdb) set logging on
(gdb) set debug infrun 1
(gdb) start
(gdb) step
5) When it stops in MsgSend, or wherever it happens to land,
kill the inferior:
(gdb) kill
... answer yes
6) Start session again; this is only because pdebug seems to
not flush the output to the log file so we need more output
to push the one we want.
(gdb) start
(gdb) q
.... y
7) on your target, kill pdebug you sterted in step  2)
8) Attach pdebug.log from your target and gdb.log from your
host to your reply.
That should give me a clue why is it stopping there.
Aleksandar
Aleksandar:
Here are the requested files.
robert
host to your reply.
Aleksandar
General
http://community.qnx.com/sf/go/post22628
Attachment: Text gdb.log 14.29 KB Text pdebug.log 62.03 KB
Thanks, that will help. I forgot, however, to ask for the
executable (or disassembly).
Here you go.
Sent: Friday, February 20, 2009 1:20 PM
abstract class
General
http://community.qnx.com/sf/go/post22648
Attachment: Text TestBed_g 11.62 KB
Thank you Robert.
The log suggests a problem in debugging support in the
kernel. I will check with the kernel people; it would be
good if you could check which procnto are you running and
give some detail on the cpu?
To check which procnto:
# pidin -p 1
Aleksandar
Aleksandar:
Okay, that's a bit of progress then.
# pidin -p 1
     pid tid name               prio STATE       Blocked
       1   1 procnto              0f READY
       1   2 procnto            255r RECEIVE     1
       1   3 procnto            255r RECEIVE     1
       1   4 procnto             11r RECEIVE     1
       1   5 procnto             10r RECEIVE     1
       1   6 procnto             40r RECEIVE     1
       1   7 procnto             10r RECEIVE     1
       1   8 procnto             20r RECEIVE     1
       1   9 procnto             10r RUNNING
       1  10 procnto             40r RECEIVE     1
As for the processor, it's an AMCC PPC405EP processor.
Cheers
Robert
Sent: Friday, February 20, 2009 1:57 PM
abstract class
Thank you Robert.
# pidin -p 1
Aleksandar
General
http://community.qnx.com/sf/go/post22653
Aleksandar:
Any news yet from the kernel people?
robert
abstract class
Thank you Robert.
# pidin -p 1
Aleksandar
General
Hello Robert,
Yes, there seems to be a fix that went in after 6.3.2
release. For more detail, however, we will have to wait for
the person who works on ppc debug support, who should be
back in the office next week.
Do you have a workaround for the time being? I can not,
unfortunately, suggest anything better than setting
breakpoints explicitly in functions/methods where you want
to stop.
You may also experiment with different procnto-s (for
example, even though it is a uniprocessor system, you could
try procnto-smp or one of the instrumented variants,
procnto-instr or procnto-smp-instr). It *might* give better
results. I can not reproduce the problem here, otherwise I
would have tried that myself.
Aleksandar
Aleksandar:
Thanks for your help. I tried using an instrumented version of the
kernel as suggested but I get the same behaviour.
I'll wait to hear back from you when the ppc debug support person
returns.
Cheers
Robert
Sent: Tuesday, February 24, 2009 10:58 AM
abstract class
Hello Robert,
to stop.
Aleksandar
General
http://community.qnx.com/sf/go/post22831
Hi Robert,
This bug was fixed after the 6.3.2 release.  It was a bug in the single
step handling in the kernel.
More specifically it was an error (as you surmised) in the handling of
the bctr* instructions.  It worked
for Aleksander because he was testing on a BookE processor, which has
hardware single step, whereas
you are using a 405 processor, which does not, and single step needs to
be emulated by the kernel.
Colin
> Aleksandar:
> returns.
> Cheers
> Robert
> abstract class
> Hello Robert,
> to stop.
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post22837
Colin:
Thanks for confirming my observations.
Can I get the fix in a patched version of procnto (I'm assuming that's
what I would need)? If so, where would I find it on the website?
Robert
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: Monday, March 02, 2009 1:40 PM
abstract class
Hi Robert,
Colin
> Aleksandar:
> returns.
> Cheers
> Robert
from
> abstract class
> Hello Robert,
> to stop.
> Thanks,
> Aleksandar
General
http://community.qnx.com/sf/go/post23240
You can try these - "standard disclaimer" - these are completely
unofficial, untested versions.  I would not use them
in a product.
If you need a supported kernel then you would have to request a Priority
Support Patch via sales.
Colin
> Colin:
> Thanks
> Robert
> abstract class
> Hi Robert,
> Regards,
> Colin
>> Aleksandar:
>> returns.
>> Cheers
>> Robert
>> -----Original Message-----
> from
>> abstract class
>> Hello Robert,
>> to stop.
>> Thanks,
>> Aleksandar
>> General
>> General
> http://community.qnx.com/sf/go/post23252
Attachment: Text procnto-400 739.04 KB Text procnto-400-instr 828.36 KB
Colin:
Thanks I'll give these a try. Do you know if there is a way I can build
my image to pick-up these 'patched' procnto's i.e. I'm assuming I would
have to modify my buildifs but not sure how to specify the non-standard
version of procnto to role into my image.
As for an official fix, can you confirm if this is fixed in the 6.4
release?
Cheers,
Robert
Sent: Monday, March 02, 2009 3:27 PM
abstract class
in a product.
Colin
> Colin:
> Thanks
> Robert
from
> abstract class
> Hi Robert,
single
to
> Regards,
> Colin
>> Aleksandar:
>> returns.
>> Cheers
>> Robert
> from
>> abstract class
>> Hello Robert,
>> to stop.
>> Thanks,
>> Aleksandar
>> General
>> General
I'm not sure how to convince the system builder to do it - maybe an IDE
person can comment?
Yes, it is fixed in the 6.4.0 release.
Colin
> Colin:
> release?
> Cheers,
> Robert
> abstract class
> in a product.
> Regards,
> Colin
>> Colin:
>> Thanks
>> Robert
> from
>> abstract class
>> Hi Robert,
> single
> to
>> Regards,
>> Colin
>>> Aleksandar:
>>> returns.
>>> Cheers
>>> Robert
>> from
>>> abstract class
>>> Hello Robert,
>>> to stop.
In image properties user can pick up any from combo box. Just before
doing your selection add customized procnto location to system searcch
path (See SB project properties ->Search Paths->System Files Tab
> person can comment?
> Regards,
> Colin
>> Colin:
>> release?
>> Cheers,
>> Robert
>> abstract class
>> in a product.
>> Regards,
>> Colin
>>> Colin:
>>> Thanks
>>> Robert
>> from
>>> abstract class
>>> Hi Robert,
>> single
>> to
>>> Regards,
>>> Colin
>>>> Aleksandar:
>>>> returns.
>>>> Cheers
>>>> Robert
>>>> Sent: Tuesday, February 24,...
Alex:
Unfortuantely, we don't use the system builder feature from the IDE to
build our system image. We run mkifs on our buildifs file to generate
the image. Any idea what to change in my buildifs then?
robert
From: Alex Chapiro [mailto:community-noreply@qnx.com]
Sent: Tuesday, March 03, 2009 2:05 PM
abstract class
IDE
> person can comment?
> Regards,
> Colin
>> Colin:
build
would
non-standard
>> release?
>> Cheers,
>> Robert
Just change the procnto-400 in your buildifs file to be the fullpath of
the new procnto-400 I gave you.
Cheers,
Colin
> Alex:
> Thanks
> robert
> abstract class
> IDE
>> person can comment?
>> Regards,
>> Colin
>>> Colin:
> build
> would
> non-standard
>>> release?
>>> Cheers,
>>> Robert
> http://community.qnx.com/sf/go/post23387
Colin:
Okay, I did that and built a new image with the modified procnto image
you provided. However I still get the same behaviour with the debugger.
Can you confirm if you sent the correct procnto binaries? Is there a
version number I can check on my end?
Cheers
Robert
Sent: Tuesday, March 03, 2009 2:27 PM
abstract class
Cheers,
Colin
> Alex:
> Thanks
> robert
from
> abstract class
> IDE
>> person can comment?
>> Regards,
>> Colin
>>> Colin:
> build
> would
> non-standard
>>> release?
>>> Cheers,
>>> Robert
General
http://community.qnx.com/sf/go/post23388
uname -a should show the build date.
I'll double check to make sure the fix integrated ok.
> Colin:
> Cheers
> Robert
> abstract class
> Cheers,
> Colin
>> Alex:
>> Thanks
>> robert
> from
>> abstract class
>> IDE
>>> person can comment?
>>> Regards,
>>> Colin
>>>> Colin:
>> build
>> would
>> non-standard
>>>> release?
>>>> Cheers,
>>>> Robert
>> General
> http://community.qnx.com/sf/go/post23396
This is what I get when I link in your procnto-400-instr
# uname -a
QNX localhost 6.3.2 2009/03/02-15:28:31EST WRM_782 ppcbe
Sent: Tuesday, March 03, 2009 2:52 PM
abstract class
> Colin:
debugger.
> Cheers
> Robert
Ok, nuts.  I finallly tracked down a 405 and the issue still happens
with 6.4.0, so the fix
we saw wasn't actually the issue after all...
*SIGH*
> # uname -a
> abstract class
>> Colin:
> debugger.
>> Cheers
>> Robert
> http://community.qnx.com/sf/go/post23401
Bummer. So should I submit a ticket to get it fixed then?
Sent: Tuesday, March 03, 2009 3:34 PM
abstract class
*SIGH*
> # uname -a
from
> abstract class
>> Colin:
> debugger.
>> Cheers
>> Robert
General
http://community.qnx.com/sf/go/post23402
I'm taking a quick look see....
> abstract class
> *SIGH*
>> # uname -a
> from
>> abstract class
>>> Colin:
> image
>> debugger.
>>> Cheers
>>> Robert
>> General
> http://community.qnx.com/sf/go/post23404
FYI I've raised PR66008 to track this.
> abstract class
> *SIGH*
>> # uname -a
> from
>> abstract class
>>> Colin:
> image
>> debugger.
>>> Cheers
>>> Robert
>> General
cburgess@qnx.com
Colin:
Is it possible (for me) to track this PR so I can see when and in what
release it gets resolved in?
Thanks again
Robert
Sent: Wednesday, March 04, 2009 9:23 AM
abstract class
from
> abstract class
> *SIGH*
>> # uname -a
> from
>> abstract class
>>> Colin:
> image
>> debugger.
>>> Cheers
>>> Robert
>> General
cburgess@qnx.com
General
http://community.qnx.com/sf/go/post23461
Unfortunately not.  We'll keep you updated though.
Regareds,
Colin
> Colin:
> Thanks again
> Robert
> abstract class
> from
>> abstract class
>> *SIGH*
>>> # uname -a
>> from
>>> abstract class
>>>> Colin:
>> image
>>> debugger.
>>>> Cheers
>>>> Robert
>>> General
>> General
>> General
cburgess@qnx.com
Just FYI, I have a candidate fix and am testing it now.
> Regareds,
> Colin
> > Colin:
> > Thanks again
> > Robert
> > abstract class
> > from
> >> abstract class
> >> *SIGH*
> >>> # uname -a
> >> from
> >>> abstract class
> >>>> Colin:
> >> image
> >>> debugger.
> >>>> Cheers
> >>>> Robert
> >>> General
> >> General
> >> General
I've attached patched versions of 6.3.2GA PPC 400 kernels for you to try.  These are unofficial, unsupported engineering
 releases and we would council against using them in a production system.
Attachment: Compressed file procnto-400.tar.gz 520.87 KB
Neil:
The patch seems to be working fine now.
Many thanks
Robert
From: Neil Schellenberger [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 11, 2009 5:28 PM
abstract class
try.  These are unofficial, unsupported engineering releases and we
General
http://community.qnx.com/sf/go/post24188
Hi Robert,
That's excellent news!  I'll do the formal backports to 6.3.2 and to
6.4.0.1 and close the PR, if that's OK with you.
Neil
On Thu, 2009-03-12 at 16:38 -0400, Robert D'Attilio wrote:
> Neil:
> Many thanks
> Robert
> abstract class
> http://community.qnx.com/sf/go/post24274
Sounds good to me.
Will there be some notification when I can pick up the official 6.3.2
patch? Also where would I download it from?
Cheers
Robert
Sent: Thursday, March 12, 2009 4:46 PM
Subject: RE: GDB (on PPC target) can't step into functions derived from
abstract class
Hi Robert,
Neil
> Neil:
> Many thanks
> Robert
from
> abstract class
General
http://community.qnx.com/sf/go/post24275
Hi Robert,
You can request Priority Support Patches for 6.3.2 through your Customer
Support Representative.
Neil
On Fri, 2009-03-13 at 10:50 -0400, Robert D'Attilio wrote:
> Sounds good to me.
> Cheers
> Robert
> abstract class
> Hi Robert,
> Regards,
> Neil
> > Neil:
> > Many thanks
> > Robert
> from
> > abstract class
> > General
> > General
> http://community.qnx.com/sf/go/post24325
Colin:
Any idea if the AMCC PPC440 processor is going to have the same issue? I
briefly spoke with their FAE and he said the 440 definitely supports
hardware-breakpoints but I'm not sure that's the same thing as hardware
single-step.
Cheers
Robert
abstract class
Hi Robert,
Colin
> Aleksandar:
> returns.
> Cheers
> Robert
from
> abstract class
> Hello Robert,
> to stop.
> Thanks,
> Aleksandar
General
The 440 is a booke kernel, I believe, which supports hardware single step.
> Colin:
> single-step.
> Cheers
> Robert
> abstract class
> Hi Robert,
> Regards,
> Colin
>> Aleksandar:
>> returns.
>> Cheers
>> Robert
> from
>> abstract class
>> Hello Robert,
>> to stop.
>> Thanks,
>> Aleksandar
>> General
>> General
> http://community.qnx.com/sf/go/post23849
cburgess@qnx.com
