Forum Topic - how does arm-gcc use fp register?: (7 Items)
I tried with -O2 to compile an test application but it still uses fp register, is this normal?
but I tried on arm host linux with native gcc 4.1.2 then I didn't see fp is used.
Re: how does arm-gcc use fp register?
Our arm tools use a different ABI than most Linux arm toolschains. We follow apcs-gnu, and they typically follow the
EABi (aapcs-linux). By default, our gcc uses -mapcs-frame which means the complaint apcs frame will be emitted. The only
 case the frame pointer is not required is in a leaf function.
Ryan Mansfield
> apcs-gnu, and they typically follow the EABi (aapcs-linux). By default, our
> The only case the frame pointer is not required is in a leaf function.
> Regards,
> Ryan Mansfield
Thanks Ryan!
It seems that apcs is out of date? apcs save at least fp,ip,lr,pc but aapcs didn't when omit-frame-pointer is enabled. I
 didn't understand why pc is saved in stack with apcs? what is that for? Also when I debug arm Linux  binary gdb still
can show backtrace, how is that done if no fp is saved.
looks like apcs-gnu will not save fp when -fomit-frame-pointer is enabled with leaf function.
but I tried -mno-apcs-frame then it will not save so many registers any more so this should be faster. why we enabled
this default? In gcc document -mno-apcs-frame is default.
-mno-apcs-frame would mean debugging would not always work properly.
-mno-apcs-frame is the default for targets that follow the newer ABIs.
Ryan Mansfield
Yao Zhao wrote:
> Thanks Ryan!
Yes, apcs is old but for us to switch would mean breaking binary
compatibility with all existing ARM binaries.
is enabled. I didn't understand why pc is saved in stack with apcs? what
is that for?
There was a historical reason for saving the PC but I can't recall at
the moment but it's rarely needed. It still gets saved because the ABI
says so.
Also when I debug arm Linux  binary gdb still can show backtrace, how is
The eabi requires per function unwind tables.
Ryan Mansfield
thanks!
now understood!
