Forum Topic - invalid string offsets when using gcc4.2.4 instead of ggc3.3.5: (7 Items)
Hi there,
hopefully this is not off topic.
I have installed QNX6.3.2. I use IBM/Rhapsody 7.4 together with gcc 3.3.5 successfully. There is a framework included in
 Rhapsody which has to be compiled. This works fine with gcc3.3.5.
For some reasons I want to change to gcc4.2.4 but I cannot upgrade to QNX6.4.0.
-> I installed gcc4.2.4 and binutils 2.18 into my existing QNX6.3.2 enviroment.
( selection of 4.2.4 in IDE and "Hello World" project working fine )
I changed the compiler version in the default file to make shure 4.2.4 is the used version.
When I rebuild the Rhapsody framework I get a lot of errormessages looking like this:
BFD: nnnn.o: invalid string offset xxxx >= yyyy for setction `.shstrtab'
The build does not break, so I guess it is not fatal error.
After I compile and link my application against the "bad" Rhapsody Libs, I get an application that is able to run on an
6.3.2 target.
Hm, do I have to care about these errors? What can I do to solve them?
Stefan
Re: invalid string offsets when using gcc4.2.4 instead of ggc3.3.5
stefan thiel wrote:
> Hi there,
in Rhapsody which has to be compiled. This works fine with gcc3.3.5.
an 6.3.2 target.
Are the 2.18 binutils being invoked when you get these warnings? Does
the build directly invoke the canonically named binutils (e.g.
i386-pc-nto-qnx6.3.0-ar)? I've seen this happen when different versions
of binutils have been mixed.
Ryan Mansfield
hi Ryan,
I had a quick look into the gcc_ntox86*.conf files and they all seem to be set up well for 2.18
As a cross check, I have renamed all ntox86-*-2.18.exe to make sure what files will be used by a rebuild. Every missing
file I renamed back step by step
Had the following results:
cc: spawn of C:\Programme\QNX632\host\win32\x86\usr\bin\ntox86-as-2.18 failed: No such file or directory
after rerenaming the assembler, the BDF: messages occured again and build completed.
-> You mentined to check files i386-pc-nto-qnx6.3.0-*, so I did the renaming things with these files
result: same without renaming, this seems to me like the i386* files from 2.18 are either not used or not needed.
next try:
I changed all lines off all gcc_ntox86*.conf files
to use
/usr/bin/i386-pc-nto-qnx6.3.0-*2.18
instead of
/usr/bin/ntox86-*2.18
exactly same behaviour and BFD errors
double checked by renaming i386-pc-nto-qnx6.3.0-as-2.18
-> result:
cc: spawn of C:\Programme\QNX632\host\win32\x86\usr\bin\i386-pc-nto-qnx6.3.0-as-2.18 failed: No such file or directory
--> maybe another file not including 2.18 in its name is causing the problem?
stefan thiel wrote:
> next try:
> to use
> instead of
> -> result:
The conf files should be calling the suffixed binutils which shouldn't
be the source of the problem. I was wondering if some other part of the
build was directly calling the 2.12 binutils. Can you paste a log of the
command that generates the warnings?
Ryan Mansfield
The build is invoked from within the Rhapsody IDE, so it's not easy to get a lot of output.
But here are the makefiles being called for this operation
QNXCWbuild.mak is the one being invoked first
Attachment: Compressed file oxf.zip 344 bytes
I tried 4.2.1.
Same BFD errors here, however the *.conf files pointing to binutils 2.17
