libecpp.so.4 causes SIGILL with "lwsync" on Freescale 8572ds
12/05/2008 10:03 PM
post18068
SDP 6.4.0; PPC board: Freescale 8572ds
While still evaluating this Freescale board, we have come across a trivial C++ construction that causes a SIGILL
(illegal instruction) inside library target/qnx6/ppcbe/lib/libecpp.so.4
static int int1 = strlen( "Blah1" );
That line by itself inside a function causes a crash that looks like this:
Process 3321871 (testit) terminated SIGILL code=1 fltno=1
ip=fe38b854(libecpp.so.4@__cxa_guard_release+0x24) mapaddr=0000b854.
ref=00000000
Illegal instruction (core dumped)
Please see the attached note for a minimal piece of source code that causes the problem inside a "testit.cpp" file. The
file is compiled this way:
qcc -V4.2.4,gcc_ntoppc -EB -DQNX -DQNX_ppc -Y_ecpp -o testit testit.cpp
Interestingly, if the file is renamed to a .c file, then it works fine, even though the compilation reports a warning:
DOS> qcc -V4.2.4,gcc_ntoppc -EB -DQNX -DQNX_ppc -Y_ecpp -o testc testc.c
testc.c: In function 'strlenInStatic':
testc.c:10: warning: initializer element is not constant
testc.c:10: warning: (near initialization for 'int1')
On x86 (running a few months old 6.4.0) there is no problem.
libecpp.so.4 library is probably compiled for a non-generic PPC processor. I disassembled libecpp.so.4 and found the
instruction call to lwsync.
0000b850 <__cxa_guard_release>:
b850: 7c 08 02 a6 mflr r0
b854: 94 21 ff f0 stwu r1,-16(r1)
b858: 48 01 8d 7d bl 245d4 <object_mutex+0x294>
b85c: 93 c1 00 08 stw r30,8(r1)
b860: 7f c8 02 a6 mflr r30
b864: 90 01 00 14 stw r0,20(r1)
b868: 89 23 00 01 lbz r9,1(r3)
b86c: 39 29 ff ff addi r9,r9,-1
b870: 99 23 00 01 stb r9,1(r3)
b874: 7c 20 04 ac lwsync <<<<<< ILLEGAL instruction for Freescale?
