Forum Topic - qcc command line option bug: (4 Items)
While substituting gcc with qcc -V3.3.5,gcc_ntox86 using QNX 6.3.2 I have found a qcc bug with parsing -pedantic option
which qcc must pass to gcc, but instead of it, it treat -pedantic as its "-p" option and enables profiling for the
compiled source code.
The same behaviour of qcc in the QNX 6.4.0.
Re: qcc command line option bug
I can confirm this, I created a pr: 63779
Do you need an experimental fix or can you wait till 6.4.1?
In the meantime, you can use "-Wc,-pedantic", which will pass down -pedantic
Cody
No, thank you, I do not need experimental fix.
I've found this problem while compilig lighttpd ( http://www.lighttpd.net/ ) - it uses -pedantic by default (with bunch
of other options), but there is not a problem to remove -pedantic string :) But finding where is the root of problem and
 why executables creating the gmon.out file costs me one hour :)
