Forum Topic - Applying a patch:
Applying a patch
How can I apply a patch to a gcc resides in Qnx ?
Xilinx has Posted a toolchain that should address the board i'm using :
ppc405 with hardware FPU support through APU Interface.
http://www.xilinx.com/guest_resources/gnu
The GPL GNU Source (9.2i Release).
I've downloaded their toolchain but i want to use it with Qnx gcc ,
inorder to be able to run Qnx on that board and use hardware FPU.
There is a bunch of pathces in the above toolchain that i want to apply to the gcc in Qnx .
Re: Applying a patch
Download the gcc source from the toolchain project on the foundry, apply
the patches and rebuild gcc. Hopefully for your sake Xilinx has provided
a set of patches against a recent version of gcc otherwise the merge
will have to be done by hand and it will likely be nontrivial.
Ryan Mansfield
- gcc source  - downloaded
- pathces  - going to be applied ...
- building gcc - where can i find the scripts and the headers  for building the gcc for the qnx os on virtex4 ppc core
platform or a standart ppc405 core .
my mistake no gcc sources on the foundery only binaries
where can i find the sources ?
can i use the sources from the standart gcc , apply Xilinx patches to it and the build it for qnx os.
how do i build the gcc for the qnx os ? (headers , scripts)
Thank you.
Vadim.
In the core development tools project besides "Forums" there is a link
to "Source".
http://community.qnx.com/sf/scm/do/listRepositories/projects.toolchain/scm
Ryan Mansfield
Found the sources
I found the sources at svn
Looking in to it , will get back to you later ...
Thank you .
