Forum Topic - gdb on QNX 6.3.2: Page 1 of 2 (30 Items)
gdb on QNX 6.3.2
I have a problem running gdb on a QNX machine, even for the most simple C
program (just a loop from 0 to 9, which prints the counter value)
The executable name is test, so in the terminal window i write:
$gdb test
I get the debugger prompt, and try to actually run, after setting a
breakpoint on "main"
(gdb) b main
Breakpoint 1 at 0x8048452: file test.c, line 7.
(gdb)r
Starting program: /home/qa/Yael/profiles/test/test
The gdb prompt is displayed again, and i don't reach the breakpoint:
(gdb) where
#0 0xb0334792 in ?? ()
I try to continue:
(gdb) c
Continuing
And nothing happens. I can't stop the execution with ctrl+C, and the
application doesn't print it's outputs. The only way out is to kill the
process from another window.
What am i doing wrong?
Yael Frommer
Software Development
Modeling Solutions Product Division
Telelogic, An IBM Company
2 Pekeris St. Tamar Park
Rehovot 76100
Israel
Phone: 972-8-9484688
Fax: 972-8-9471313
Re: gdb on QNX 6.3.2
Are you using gdb shipped with 6.3.2?
Could you post what is printed when you start gdb (it should
print information about how it was configured, this is just
for me to confirm which gdb it is)?
Is your 'test' application running correctly without the
debugger?
Aleksandar
Yes, i'm using the gdb shipped with 6.3.2.
The test application runs correctly without the debugger.
The message printed when i start gdb is:
$ gdb ./test
GNU gdb 5.2.1qnx-nto
Copyright 2002 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "ntox86"...
It is supposed to work.
What gcc version are you using?
Could you try a "Hello World" application? Does it work?
If the sample code you mentioned is not something
proprietary, could you attach the project? I would like to
try to reproduce.
Aleksandar
The test application i'm running is basically a "Hello World" application.
The code is :
#include <stdio.h>
void main()
  int i;
  for (i=0; i<10; i++)
    printf("Value of counter is %d\n", i);
About the gcc version - I'll answer you tomorrow, when i get to the
office.
Does the gdb configuration look ok?
thanks for your help,
Yael
Aleksandar Ristovski <community-noreply@qnx.com>
To:
general-toolchain <post16379@community.qnx.com>
Date:
11/11/2008 04:50 PM
Subject:
try to reproduce.
Aleksandar
General
http://community.qnx.com/sf/go/post16379
Yes, I just wanted to make sure that is the gdb that comes
with 6.3.2.
> The code is :
> #include <stdio.h>
> void main()
>   int i;
> office.
If you are using just 6.3.2 target, gcc is probably 2.93.3.
I just tried and it worked for me.
Below is my debugging session using the code above. Note
that after starting the program, gdb will stop on a shared
library event. It is not supposed to stop here, but it
stops. In any case, if you just continue at that point that
will take you to the breakpoint set in main.
I think what was happening in your case is that you were
trying to use gdb when it is stopped due to shared library
event; gdb 5.2.1 does not behave well at that early stage of
program loading, but continuing on that breakpoint should
take you to more friendly debugging session.
Note also that I compiled the program using -g compiler
option and turning off all optimizations (-O0). It is very
difficult to debug program without debug information;
therefore, use -g whenever you need to debug your
application. Optimizations do not have to be turned off, but
expect odd behaviour: you may be stepping line by line and
see that gdb is "jumping" all over the place. Optimizations
will do that. Use the lowest optimization level you can
under given circumstances.
Finally, I would encourage you to use the newer gdb-6.7
which you can download from here:
http://community.qnx.com/sf/frs/do/listReleases/projects.toolchain/frs.gdb
Try the latest update, it should work just fine on 6.3.2.
----------------------- session -------------------------
# gcc -v
Reading specs from
/usr/qnx632/host/qnx6/x86/usr/lib/gcc-lib/ntox86/2.95.3/specs
gcc version 2.95.3
# gcc -o test -O0 -g test.c
test.c: In function `main':
test.c:4: warning: return type of `main' is not `int'
# gdb ./test
certain conditions.
(gdb) b main
Breakpoint 1 at 0x8048452: file test.c, line 6.
(gdb) r
Starting program: /tmp/test
(gdb) c
Continuing.
[Switching to process 1212460]
Breakpoint 1, main () at test.c:6
6         for (i=0; i<10; i++)
(gdb) step
7           printf("Value of counter is %d\n", i);
(gdb) step
Value of counter is 0
(gdb)
(gdb)
Value of counter is 1
(gdb)
(gdb)
Value of counter is 2
(gdb)
(gdb)
Value of counter is 3
(gdb) c
Continuing.
Value of counter is 4
Value of counter is 5
Value of counter is 6
Value of counter is 7
Value of counter is 8
Value of counter is 9
Program exited normally.
(gdb) q
--------------------- session end ------------------
The gcc version i have is 2.95.3.
I recompiled my code as you suggested, with -g and -O0, but the results
were the same:
My debugging session behaves just like yours up to the point where you
press 'c' (continue). When i press 'c' i wait and wait and wait and
nothing happens... Only if i kill the gdb process (from another terminal)
the "block" is released and the application runs to completion:
(gdb) c
Continuing.
                       <---- here i wait and wait and nothing..
Value of counter is 0  <----- These are printed after i kill the gdb
Terminated
I will check the possibilty to download a newer gdb version, but other
than that - any ideas what could be the problem? or what more i can do to
help identify the problem? could it be a problem with a shared library
used by gdb?
thanks,
Yael
To:
general-toolchain <post16394@community.qnx.com>
Date:
11/11/2008 05:51 PM
Subject:
application.
> The code is :
> #include <stdio.h>
> void main()
>   int i;
> office.
# gcc -v
Reading specs from
gcc version 2.95.3
# gdb ./test
certain conditions.
(gdb) b main
(gdb) r
(gdb) c
Continuing.
(gdb) step
7  ...
> were the same:
> (gdb) c
> Continuing.
Could you at this point (where you wait) use pidin in
another terminal and post the output here?
BTW can you try to debug using IDE? It is straightforward to create a simple program in IDE and run remote debugging.
>> were the same:
>> (gdb) c
>> Continuing.
> http://community.qnx.com/sf/go/post16462
This is the output of pidin :
$ pidin
     pid tid name               prio STATE       Blocked
       1   1 procnto              0f READY
       1   2 procnto             10r RECEIVE     1
       1   3 procnto             10r RECEIVE     1
       1   4 procnto             10r RECEIVE     1
       1   5 procnto             10r RECEIVE     1
       1   6 procnto             10r RECEIVE     1
       1   7 procnto             10r RUNNING
       1   8 procnto             10r RECEIVE     1
       1   9 procnto             10r RECEIVE     1
       1  10 procnto             10r RECEIVE     1
       1  11 procnto             10r RECEIVE     1
       2   1 sbin/tinit          10o REPLY       1
    4099   1 proc/boot/pci-bios  12o RECEIVE     1
    4100   1 proc/boot/slogger   10o RECEIVE     1
    4101   1 proc/boot/io-usb    10o SIGWAITINFO
    4101   2 proc/boot/io-usb    21r RECEIVE     4
    4101   3 proc/boot/io-usb    21r RECEIVE     1
    4101   4 proc/boot/io-usb    10o RECEIVE     7
    4101   5 proc/boot/io-usb    10r NANOSLEEP
    4101   6 proc/boot/io-usb    10o RECEIVE     7
    4102   1 proc/boot/io-hid    10o SIGWAITINFO
    4102   2 proc/boot/io-hid    10o RECEIVE     4
    4102   3 proc/boot/io-hid    10o RECEIVE     4
    4102   4 proc/boot/io-hid    10r REPLY       4101
    4102   5 proc/boot/io-hid    15r RECEIVE     12
    4102   6 proc/boot/io-hid     9r RECEIVE     16
    4103   1 /boot/devc-con-hid  20o RECEIVE     1
    4103   2 /boot/devc-con-hid  10o REPLY       4102
    8200   1 roc/boot/devb-eide  10o SIGWAITINFO
    8200   2 roc/boot/devb-eide  21r RECEIVE     1
    8200   3 roc/boot/devb-eide  21r RECEIVE     4
    8200   4 roc/boot/devb-eide  10o RECEIVE     10
    8200   5 roc/boot/devb-eide  10o RECEIVE     7
    8200   6 roc/boot/devb-eide  10o RECEIVE     7
    8200   7 roc/boot/devb-eide  10o RECEIVE     7
    8200  11 roc/boot/devb-eide  10o RECEIVE     7
    8201   1 oc/boot/umass-enum  10o SIGWAITINFO
    8201   2 oc/boot/umass-enum  10r REPLY       4101
   16394   1 sbin/pipe           10o SIGWAITINFO
   16394   2 sbin/pipe           10o RECEIVE     1
   16394   3 sbin/pipe           10o RECEIVE     1
   16394   4 sbin/pipe            9o RECEIVE     1
   16394   6 sbin/pipe           10o RECEIVE     1
   20491   1 sbin/mqueue         10o RECEIVE     1
   77837   1 sbin/io-audio       10o SIGWAITINFO
   77837   2 sbin/io-audio       10o RECEIVE     1
   77837   3 sbin/io-audio       10o RECEIVE     1
   77837   4 sbin/io-audio       10o RECEIVE     1
   77837   5 sbin/io-audio       50r INTR
   94223   1 sbin/devc-ser8250   24o RECEIVE     1
   94226   1 sbin/devc-par       10o RECEIVE     1
   94226   2 sbin/devc-par        9r CONDVAR     8053e00
   94228   1 sbin/io-net         10o SIGWAITINFO
   94228   2 sbin/io-net         10o RECEIVE     5
   94228   3 sbin/io-net         10o RECEIVE     1
   94228   4 sbin/io-net         10o RECEIVE     1
   94228   5 sbin/io-net         10o RECEIVE     1
   94228   6 sbin/io-net         21r RECEIVE     19
  110614   1 usr/sbin/spooler    10o NANOSLEEP
  131086   1 sbin/devb-fdc       10o SIGWAITINFO
  131086   2 sbin/devb-fdc       21r RECEIVE     1
  131086   3 sbin/devb-fdc       10o RECEIVE     7
  131086   4 sbin/devb-fdc       10o RECEIVE     4
  131086   5 sbin/devb-fdc       10o RECEIVE     4
    131086   6 sbin/devb-fdc       10o RECEIVE     4
  139276   1 sbin/devc-pty       10o RECEIVE     1
  143376   1 usr/sbin/random     10o SIGWAITINFO
  143376   2 usr/sbin/random     10o RECEIVE     1
  143376   3 usr/sbin/random     10o NANOSLEEP
  155665   1 usr/sbin/dumper     10o RECEIVE     1
  163861   1 usr/sbin/inetd      10o SIGWAITINFO
  167955   1 usr/sbin/qconn      10o SIGWAITINFO
  167955   2 usr/sbin/qconn      15o RECEIVE     1
  167955   3 usr/sbin/qconn      10o CONDVAR     805dfc8
  167955   4 usr/sbin/qconn      10o RECEIVE     4
  184343   1 bin/login        ...
Apparently the problem i have with gdb has something to do specifically
with the host from which i connect (through phindows) to the target qnx
machine.
I found that if i work directly on the target (not through phindows), gdb
runs ok.
I also found that when connecting through phindows to the target from
another host (not my PC), gdb also runs Ok.
So what can be the problem with my host (maybe keyboard or mouse
settings?) that causes this?
> machine.
> runs ok.
Ok, now I think I know what the problem is; there is a PR on
this (PR24823). Gdb inherits sigmask from the phindows and
it shouldn't.
You do, however, have alternatives:
1) use telnet to connect to your target.
2) use host-side momentics and debug your program remotely
from command line or using IDE
The telnet option works, but not the host-side momentics.
Trying to debug the application through momentics crashes immediately,
before i even reach main, and this is what i see in the IDE debug window:
I'm not sure this is the same sigmask problem, but other host machines
don't have this problem.
Is there a way to control the sigmask setting in momentics or phindows ?
Could you repeat what do you see in the IDE debug window? It
shouldn't be related to the phindows issue. Maybe it's
something else.
I hope you can see the attached bitmap - a snapshot of the momentics IDE
debug window.
If i connect through telenet to the qnx target machine, i can debug this
exe with no problem, but through momentics it crashes even before it
starts.
Attachment: Text momentics_dbg.bmp 1.04 MB
> debug window.
> starts.
Yes, I can see the bitmap. It is very strange there are no
symbols.
I have to ask more questions:
1) what version of momentics did you install on your host side?
2) Please attach complete build-log after rebuilding your
project.
3) Please attach complete debugger log for the failing session.
Momentics version on the host: 6.3.0 Service Pack 3.
Complete build-log and debug-log are attached, as well as the host's "
Help->About QNX Momentics IDE" window
Attachment: Text build_log.bmp 3.14 MB Text debug_log.bmp 3.27 MB Text host_momentics_ver.bmp 580.18 KB
So you host is 6.3.0 SP3 and your target is 6.3.2? That is where library mismatch is coming from.
> http://community.qnx.com/sf/go/post16759
Yes, if they do not match you will definitely have problems
debugging your applications. Gdb on your host side uses
libraries on the host which are different than the ones on
the target (this, in general case, makes debugging session
unusable even if it doesn't fail like yours does).
You may still be able to run the application built with
6.3.0 momentics - try running instead of debugging the
application, or copy your binary to the target and run it
usinig telnet; but that wouldn't make any difference with
regards to debugging it from your host.
In any case, you will want matching momentics for your
development. Note that after you get the matching momentics,
you can upgrade GDB with the updates posted on the foundry.
Indeed this was a host/target compatibility issue, problem solved now.
Thanks you very much!
This is not IDE from 6.3.2 btw.
from FAQ:
  Q: I am trying to debug simple program and it SIGSEGV before entering main. It runs fine without debugger. What can I
do?
This is usually a symptom of a library host/target mismatch.
For example when you run Momentics 6.3.2 on the target and Momentics 6.4.0 on the host.
When using gdb version 6.7 or greater (available from Foundry 27, independent of Momentics)
it will print a warning about a library mismatch to the console.
This can also happen if you applied libc patch on the host and not on the target (and vice versa).
Is there an editor (like emacs on Unix) for qnx, where i can run gdb in?
I think someone got emacs going, but also checkout cgdb - it's an easy port
> http://community.qnx.com/sf/go/post16511
cburgess@qnx.com
You can also use your linux host and use gdb in a remote
session. You would need momentics installed on the host and
qconn running on the target.
>> General
