Forum Topic - gdb code alignment problem: (3 Items)
We have a customer that sends us core dumps that, when loaded into gdb, do not line up with our code listings.  When we
do a 'where', it displays a stack that can't possibly exist.  Looking at variables is also not possible.  We have to
drop down in to assembly code and make guesses to solve problems.  When we disassemble, we discover the problem (and it
has not been stack corruption) but it is very time consuming.  Yes, we've used the exact code stream in gdb used to
build the version the customer runs.
We've checked gcc, gdb and library versions used by our program and they all match between us and the customer.  The
only difference is the customer uses 6.3.0 SP2 and we built on 6.3.0 SP3.
gcc 2.95.3
gdb 5.2.1qnx-nto
libsocket.so.2 => /lib/libsocket.so.2 (0xb8363000)
libm.so.2 => /lib/libm.so.2 (0xb8387000)
libcpp.so.3 => /lib/libcpp.so.3 (0xb83a3000)
librpc.so.2 => /usr/lib/librpc.so.2 (0xb8417000)
libc.so.2 => /usr/lib/ldqnx.so.2 (0xb0300000)
Any suggestions on how to figure out our problem?
Ed
Re: gdb code alignment problem
Could you try with the latest gdb-6.7?
http://community.qnx.com/sf/frs/do/listReleases/projects.toolchain/frs.gdb
Aleksandar
After rereading your post, I don't think you can get any useful results the way you are trying to: it is highly likely
that between SP2 and SP3 there were changes in shared libraries. It is sufficient to have one function changed and
everything in the library can be shifted.
Core is basically a memory dump. Therefore, even the slightest difference in binaries that generated the dump
(executable + shared object) will make core next to unusable (in terms of debugging it with gdb). Example: core
specifies current instruction pointer; gdb uses that to lookup binary it has (let's assume its somewhere within libc);
if libraries differ, what gdb finds will not correspond to what was there on the target. The same applies to unwinding
process, it will use stack pointer and memory dump from the core, but all addresses will be looked up in local shared
libraries, in your case SP3 ones which will very likely have something unrelated at those addresses.
Therefore, what you absolutely need is *exactly* the same binareis. Luckily, you do not need to build everything on your
 machine, you can get all the shared libraries involved from your customers' machine, including core and the binary
causing the core. Having all that in place, you should be able to get meaningful results even with gdb-5.2.1
Hope this helps,
Aleksandar
