Forum Topic - GCC does not handle uint64 as a 64 bit targeting x86:
I am trying to do some large integer math.  I have tried _uint64 and uint64_t and unsigned long long but all I get are
32 bit values.
I am targeting x86 and using GCC 3.3.5.  In every case I get an error that the integer constant is too large.
It seems very strange that a 64 bit unsigned integer is not supported.  Is this deliberate or is it a compiler problem
or ???
Is there any work around?
Thanx
Tim
Re: GCC does not handle uint64 as a 64 bit targeting x86
Ok, it seems that I need to add "LL" and not just "L" to the constant.  Which makes sense, but wasn't my first thought.
Things seem to be working correctly now.
