Forum Topic - wide character (wchar_t) support?: (2 Items)
I am using autotools to build C++ programs on Win32/Cygwin for QNX (i386 on VMWare).  I can successfully build code that
 uses the std c++ library with the exception of anything that requires wchar_t.  These same programs build successfully
within the Momentics IDE so I know that I must be invoking the compiler/linker incorrectly (missing some library?)  but
not in an obvious way ..
Typically, I run configure like this:
configure --host=i386-pc-nto-qnx6.3.0
and everything builds fine (including compiles, I use -D_GLIBCPP_USE_WCHAR_T) until I get to the link step in which I
get:
undefined reference to `std::basic_string<wchar_t, std::char_traits....`
Any help greatly appreciated .. happy to provide my config.log if interested ...;-)
-Bob Barcklay
Re: wide character (wchar_t) support?
that uses the std c++ library with the exception of anything that requires wchar_t.  These same programs build
successfully within the Momentics IDE so I know that I must be invoking the compiler/linker incorrectly (missing some
library?)  but not in an obvious way ..
get:
In libstdc++-v3 iconv is used for wchar_t to char conversions and the
configure script checks for iconv headers and other XSI extensions such
as langinfo.h which the OS does not currently support.
Ryan Mansfield
