Forum Topic - Disappearing binaries ...: (5 Items)
I could not find an appropriate forum for this and hence...
This is regarding a very very strange behaviour I am observing on a freescale powerPC platform. The problem is that few
binaries (related to USB in my case) just DISAPPEAR from the filesystem when executed once. I mean you can see they are
present just before executing them, and you execute them and they DO get executed, but then Poof! they are gone:
# pwd
/proc/boot
# ls u* i*
i2c-mpc5200    io-net         umount         usb
ifconfig       io-usb         uname
Process 24589 (ls) exited status=0.
# usb
usb: unable to connect to USB - No such file or directory
Process 32781 (usb) exited status=1.
# usb
ksh: usb: not found
# us
ksh: us: not found
# usb
ksh: usb: not found
# ls u* i*
Process 40973 (ls) exited status=0.
Can some one please suggest what could be the reason? The same is happening with "io-usb" binary. Please note that this
is only happening with some binaries. The othe rbinaries in the same binary (say "kill") are working fine...
I'm really puzzled.
Rajat
Re: Disappearing binaries ...
I found a work around immediately after posting my query. But I still do not know the reason of the problem.
The "problematic" binaries were included at the begining of the build script (near to libc.so). When I included them in
the end of the build script, everything is OK. Although I don't undertsand this ...
Rajat
> near to libc.so). When I included them in the end of the build script,
> Thanks,
> Rajat
Can You post your complete buildfile ?
Jeevan
RE: Disappearing binaries ...
Here is the buildfile that works. Please note the location of following
binaries in the end:
usb
io-usb
devu-ehci-8349.so
libusbdi.so
If I move these to just after where libc.so is included, the problemn
appears...
Rajat
----Original Message----
From: Jeevan Mathew [mailto:community-noreply@qnx.com]
Sent: Friday, October 03, 2008 4:53 PM
To: general-toolchain
Subject: Re: Disappearing binaries ...
>> Hi,
>> script ( near to libc.so). When I included them in the end of the
>> Thanks,
>> Rajat
> Jeevan
> http://community.qnx.com/sf/go/post14402
Attachment: Text build 12.31 KB
Re: RE: Disappearing binaries ...
Hi Rajat,
have a look here:
http://www.qnx.com/developers/docs/6.3.2/neutrino/utilities/m/mkifs.html#data
and then here:
http://www.qnx.com/developers/docs/6.3.2/neutrino/utilities/m/mkifs.html#XIPvsCopy
So [data=c] directive/attribute is mandatory , if you want to run a programm multiple times.
Hope this helps.
Jeevan
> usb
> io-usb
> devu-ehci-8349.so
> libusbdi.so
> appears...
> Thanks,
> Rajat
> >> Hi,
> >> Thanks,
> >> Rajat
> > Jeevan
> > General
