Forum Topic - Linking a DLL with a shared library possible?:
We have 3 QNX C/C++ projects.  An application, a dynamic shared library and a DLL.  The application will use the DLL and
 the SO, while the DLL will also need to use functions from the SO.  However, I can't get the DLL to link against the SO
 project.  It appears to be trying to find the SO under:
TestSO/x86/dll
rather than
TestSO/x86/so
based on the EXTRA_LIBVPATH line in common.mk for the DLL project.
EXTRA_LIBVPATH+=$(PROJECT_ROOT)/../TestSO/$(CPU)/$(patsubst so%,so%,$(notdir $(CURDIR)))
How do I get the DLL to link against the SO?
Gordon Molek
Zebra Technologies Corp.
Re: Linking a DLL with a shared library possible?
Ok, by changing the LIBVPATH line to:
EXTRA_LIBVPATH+=$(PROJECT_ROOT)/../TestSO/$(CPU)/$(subst dll,so,$(subst Unittest,g,$(notdir $(CURDIR))))
The DLL completes linking, but under the Binaries"folder" in the C/C++ Projects view (and in the x86/dll directory) I
see a ".so" rather than a ".dll".
Is it a simple matter of renaming the file to ".dll"?
You don't need to link to a DLL at compile time. Dynamic link libraries
have a .so extension under QNX and generally any UNIX based operating
system. Generally, shared libs are found in /lib and /usr/lib while
DLL's a found in /lib/dll. The intention of a DLL is to link dynamically
at run-time using the dlopen/dlsym/dlclose functions.
For more information on dlsym and example source, you can take a look at
the following link:
http://www.qnx.com/developers/docs/6.3.2/neutrino/lib_ref/d/dlsym.html
> http://community.qnx.com/sf/go/post14086
