Forum Topic - gmtime() bug (or deeper?): (8 Items)
I am debugging an app, and data is being corrupted during a call to gmtime(). I looked through the source and traced the
 app via gdb, and the culprit appears to be the _Getrules() function in /lib/c/time/xgetrules.c. I have yet to prove
this, but at the very beginning of that function, I see the following:
#ifdef __QNX__
	static const char *olddst;
	static Dstrule *rules;
#else
	static const char *olddst = 0;
	static Dstrule *rules = NULL;
#endif
followed by code that references both olddst and rules before they are initialized. Does that make any sense?
(p.s. is this a good forum to post this sort of thing, or should I use one of the forums under the OS project?)
Post Deleted
Re: gmtime() bug (or deeper?)
I deleted my previous post; I was too quick to reply... they are static, so they should get initialized to 0
Could  you give more detail on the problem you are having?
Still it's an odd construct, since it implies that the initialization is not performed under QNX, but I agree it should
make no difference. The problem I am having is an unrelated variable is getting clobbered during a call to gmtime(), and
 apparently somewhere in _Getrules(). I will dig deeper. Obviously it could be my own fault.
Post Deleted
There's nothing (I know of) wrong with gmtime. Turned out to be a memory
allocation problem in my code resulting from a strange compiler
optimization and linking issue. Sorry for the noise.
Aleksandar Ristovski wrote:
> Could you post the line where you call gmtime? (and definition of the time_t variable you are passing in).
Unfortunately that doesn't appear to be the whole problem. I will keep looking.
libc is part of the OS project so any issues with it should be discussed
in the OS forums.
Ryan Mansfield
