Forum Topic - function instrumentation not working for shared objects: (11 Items)
today I tried to do some profling of a dll using the "new" Appplication Profiler 2 which is using the -finstrument-
functions.
I already did this for executable binaries and it is working fine.
Trying to apply this to a shared object seams to be not working.
I compiled the sources using -finstrument-functions and added -lprofilingS to the link list.
go ahead to the target side set QPROF_FILE and start a test binary which loads this shared object by forcing it to be
load using LD_PRELOAD
The binary terminates as expected, but there is no *.ptrace file available as it is set in QPROF_FILE
Is this a bug, or is it expected not to work for shared objects.
give me a ping if to x-post to the IDE forum.
thanks
hp
Re: function instrumentation not working for shared objects
You instrumented only shared library and not binary right?
Right now profiling is started when instrumented "main" function is hit
(to avoid dead-lock when actual libc.so is instrumented).
To turn off this behavior you can use env variable QPROF_NO_MAIN=1
Hans-Peter Reicher wrote:
Profiler 2 which is using the -finstrument-functions.
to the link list.
loads this shared object by forcing it to be load using LD_PRELOAD
> thanks
> hp
> http://community.qnx.com/sf/go/post8423
AW: function instrumentation not working for shared objects
I tried the QPROF_NO_MAIN but no change,
so I tried also the QPROF_AUTO_START which I've seen in the strings output
but that also did not change a thing.
Could it be a problem of the LD_PRELOAD usage?
>Von: Laskavaia, Elena
>Gesendet: Montag, 26. Mai 2008 16:31
>An: general-toolchain
>Betreff: Re: function instrumentation not working for shared objects
>function is hit (to avoid dead-lock when actual libc.so is
>instrumented).
>> Hi,
>> Appplication
>> -lprofilingS
>to the link list.
>> which
>> available
>> thanks
>> hp
>> General
>General
>http://community.qnx.com/sf/go/post8432
Geschaeftsfuehrung:  Dr. Wolfgang Ptacek  -  Michael Mauser  -  Regis Baudot
Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRB 361395
Re: AW: function instrumentation not working for shared objects
auto-start is on by default (but the start point is usually main).
Can you try to instrument binary (where main is) and try again?
If it works problem with  QPROF_NO_MAIN. Can you copy you command line
here (including setting env vars?)
>> instrumented).
>>> Hi,
>>> Appplication
>>> -lprofilingS
>> to the link list.
>>> which
>>> available
>>> thanks
>>> hp
>>> General
>> General
Baudot
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail
loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte
are not the intended recipient (or have received this e-mail in error)
unauthorized copying, disclosure or distribution of the contents in this
> http://community.qnx.com/sf/go/post8448
AW: AW: function instrumentation not working for shared objects
Hi Elena,
some time has gone since this was on my list of topics, I guess you know quite well the priority problems ...
I come along this issue again after a colleague had also some problems.
It turns out that this is not only a problem of shared libs,
but instead is a problem in general as long as you don't compile your main() using -finstrument-functions
The specified env variable QPROF_NO_MAIN does not have any effect to this.
any suggestions?
TIA
/hp
>Gesendet: Dienstag, 27. Mai 2008 15:21
>Betreff: Re: AW: function instrumentation not working for
>shared objects
>command line here (including setting env vars?)
>> I tried the QPROF_NO_MAIN but no change, so I tried also the
>> QPROF_AUTO_START which I've seen in the strings output but that also
>>> instrumented).
>>>> Hi,
>>>> Appplication
>>>> -lprofilingS
>>> to the link list.
>>>> which
>>>> available
>>>> thanks
>>>> hp
>>>> General
>>> General
>Baudot
>HRB 361395
>> Diese E-Mail enthaelt vertrauliche...
RE: AW: function instrumentation not working for shared objects
Profiling library was changed for GA - QPROF_NO_MAIN does not have any impact anymore.
If you instrument any function - in library or not it should generate events.
How are you running it?
QPROF_KERNEL_TRACE=1 ./app #system wide mode, kernel trace logger has to run in parallel
QPROF_FILE=/tmp/trace ./app #single app trace mode
Make sure you using library (static library libprofilingS.a on host) of latest version
From: Hans-Peter Reichert [mailto:community-noreply@qnx.com]
Sent: February 11, 2009 10:52 AM
To: general-toolchain
Subject: AW: AW: function instrumentation not working for shared objects
Hi Elena,
It turns out that this is not only a problem of shared libs, but instead is a problem in general as long as you don't
compile your main() using -finstrument-functions The specified env variable QPROF_NO_MAIN does not have any effect to
this.
any suggestions?
TIA
/hp
>Betreff: Re: AW: function instrumentation not working for shared
>objects
>>> instrumented).
>>>> Hi,
>>>> Appplication
>>>> -lprofilingS
>>> to the link list.
>>>> which
>>>> available
>>>> thanks
>>>> hp
>>>> General
I am just doing
	export QPROF_KERNEL_TRACE=1
	tracelogger -n0 -w -M -S10M &
	./app -options
my app is linked agains libprofilingS.a
checking app with "strings app|grep QPROF" is howing the env var names
I am using the profiling lib from 1_2.zip file
as soon as I add main.c to the list of files processed with -finstr...
everything is fine.
>Von: Elena Laskavaia [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 11. Februar 2009 17:46
>Betreff: RE: AW: function instrumentation not working for
>shared objects
>generate events.
>logger has to run in parallel QPROF_FILE=/tmp/trace ./app
>-----Original Message-----
>shared objects
>Hi Elena,
>any suggestions?
>TIA
>/hp
>>objects
>command line
>that also
>shared objects
>>>> instrumented).
>>>>> Hi,
>>>>> Appplication
>>>>> I compiled the...
This is not latest version then... You need it for 6.3.2? I can pull out latest version from 6.4.0 but it won't link on
6.3.2, I would have to re-build it...
Sent: February 11, 2009 11:53 AM
I am just doing
	./app -options
checking app with "strings app|grep QPROF" is howing the env var names I am using the profiling lib from 1_2.zip file
everything is fine.
>Betreff: RE: AW: function instrumentation not working for shared
>objects
>impact anymore.
>events.
>to run in parallel QPROF_FILE=/tmp/trace ./app #single app trace mode
>objects
>Hi Elena,
>any suggestions?
>TIA
>/hp
>>objects
>command line
>that also
>shared objects
>>>> instrumented).
>>>>> Hi,
>>>>> today I tried to do some profling of a dll using the "new"...
I would use my own implementation if you coudl supply me the correct parameters for TraceEvent()
I already tried my own lib defining the __cyg_profile functions with this calls:
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, _NTO_TRACE_SYSTEM, _NTO_TRACE_SYS_FUNC_EXIT, (unsigned)this_fn,
(unsigned)call_site );
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, _NTO_TRACE_SYSTEM, _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)this_fn,
But sadly IDE is not displaying is in the right way
Event, Time, Owner, CPU, Type, Data
34940, 2s 470ms 847us, prof_pp (540707) Pong Thread (3), 1, Class 13 Event 10,
34941, 2s 470ms 848us, prof_pp (540707) Pong Thread (3), 1, Class 13 Event 11,
are the used defines OK?
or do I have to use different values in 6.3.2?
/hp
>Gesendet: Mittwoch, 11. Februar 2009 17:57
>shared objects
>shared objects
>I am just doing
>	./app -options
>everything is fine.
>>objects
>have any
>>impact anymore.
>>events.
>>objects
>>Hi Elena,
>problems.
>>any suggestions?
>>TIA
>>/hp
>>>objects
>>>Can you try...
Re: AW: AW: function instrumentation not working for shared objects
It is on the wiki page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDE4.5ApplicationProfilerTrial
Enter event:
#include <sys/trace.h>
void * from = __builtin_return_address(0); // this function address
void * callsite = __builtin_return_address(1); // calling function address
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, _TRACE_SYSTEM_C >> 10, _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)from,
(unsigned)callsite);
Exit event:
TraceEvent( _NTO_TRACE_INSERTSCLASSEVENT, _TRACE_SYSTEM_C >> 10, _NTO_TRACE_SYS_FUNC_EXIT, (unsigned)from,
> /hp
>> shared objects
>> shared objects
>> I am just doing
>> 	./app -options
>> everything is fine.
>>> objects
>> have any
>>> impact anymore.
>>> events.
AW: AW: AW: function instrumentation not working for shared objects
just got it, I had forgotten that there are different defines and enums
and I was wrongly using the enum
it is working!
thanks
/hp
>Gesendet: Mittwoch, 11. Februar 2009 18:23
>Betreff: Re: AW: AW: function instrumentation not working for
>shared objects
>Enter event:
>address void * callsite = __builtin_return_address(1); //
>calling function address TraceEvent(
>_NTO_TRACE_SYS_FUNC_ENTER, (unsigned)from, (unsigned)callsite);
>Exit event:
>10, _NTO_TRACE_SYS_FUNC_EXIT, (unsigned)from, (unsigned)callsite);
>> _NTO_TRACE_SYS_FUNC_EXIT, (unsigned)this_fn, (unsigned)call_site );
>> _NTO_TRACE_SYS_FUNC_ENTER, (unsigned)this_fn, (unsigned)call_site );
>> But sadly IDE is not displaying is in the right way Event, Time,
>> Owner, CPU, Type, Data 34940, 2s 470ms 847us, prof_pp (540707) Pong
>> Thread (3), 1, Class 13 Event 10, 34941, 2s 470ms 848us, prof_pp
>> /hp
>>> objects
>can pull
>>> out latest version from 6.4.0 but it won't link on 6.3.2, I would
>>> objects
>>> I am just doing
>>> 	./app -options
>>> my app is linked agains libprofilingS.a checking app with "strings
>profiling
>-finstr...
>>> everything is fine.
>>>> objects
>>> have any
