Source Code
Source Code
Forum Topic - Qcc and spaces in arguments: (3 Items)
I'm trying to manually invoke qcc with some -D options which has some spaces in it:
qcc -DTYPE="unsigned int" main.c
This works fine using gcc, but fails with the following message with qcc:
cc1: fatal error: "-DTYPE=unsigned int": Invalid argument
This is the same kind of error that appears when trying to use spaces in paths.
Am I missing something or is there a workaround?
Cheers,
Tom
RE: Qcc and spaces in arguments
What version of qcc.
This works for me.
qcc -DTYPE="unsigned int" test.c
as a W/A you could try
qcc -Wc,-DTYPE="unsigned int" test.c
Sent: Wednesday, May 29, 2019 09:35
To: general-toolchain
Subject: Qcc and spaces in arguments
Cheers,
Tom
General
http://community.qnx.com/sf/go/post119715
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
Re: RE: Qcc and spaces in arguments
Sorry I forgot about those informations:
I'm running it on Windows 10, I think I'm using QNX 7.0.0 and qcc -V returns the following:
        5.4.0,gcc_ntoaarch64le
        5.4.0,gcc_ntoaarch64le_cxx
        5.4.0,gcc_ntoaarch64le_gpp
        5.4.0,gcc_ntoarmv7le
        5.4.0,gcc_ntoarmv7le_cxx
        5.4.0,gcc_ntoarmv7le_gpp
        5.4.0,gcc_ntox86        (default)
        5.4.0,gcc_ntox86_64
        5.4.0,gcc_ntox86_64_cxx
        5.4.0,gcc_ntox86_64_gpp
        5.4.0,gcc_ntox86_cxx
        5.4.0,gcc_ntox86_gpp
Also, adding -Wc does not change the output:
qcc -Wc,-DTYPE="unsigned int" main.c
compilation terminated.
