05/14/2008 4:03 PM
post8062
I have a project sitting on a QNX6 box. I can build it either from QNX6 or from the IDE hosted on Windows, mix the two.
The QNX6 disk is mounted via smbd, and I got Eclipse 4.5 setup to point to the project on the QNX6 box. Everything
is based on custom makefiles. Because make is launches from the same set of files the compiler/linker options are
identical in both cases.
Now the problem is that the executable generated from QNX6 and Windows are of different size and by a lot. We are
talking 90K difference ( on a 200k executable) once striped the difference goes down to 14K which is still a lot.
From what I can gather the Windows version seems to pull out more stuff from libgcc.a then the QNX setup does.
The following is some stuff is a small sample of entries I see in the map file generated by the Windows host that are
not QNX host:
C:/QNX632/host/win32/x86/usr/lib/gcc-lib/i386-pc-nto-qnx6.3.0/3.3.5/libgcc.a(unwind-dw2-fde.o)
C:/QNX632/host/win32/x86/usr/lib/gcc-lib/i386-pc-nto-qnx6.3.0/3.3.5/libgcc.a(unwind-dw2.o)
(_Unwind_Find_FDE)
(_Unwind_Find_FDE)
.text 0x080676f0 0x164c C:/QNX632/host/win32/x86/usr/lib/gcc-lib/i386-pc-nto-qnx6.3.0/3.3.5/libgcc.a(unwind
-dw2.o)
0x08068cb0 _Unwind_GetIP
0x08068b18 _Unwind_Resume_or_Rethrow
0x080678ec _Unwind_GetRegionStart
0x08068bf4 _Unwind_Backtrace
I have attached the two mapfiles. Suggestion welcome.
