Forum Topic - hidden symbol `_Unwind_Resume' error with GCC 4.9.3 and QNX SDP 6.6.0:
HI Everyone,
I am trying to upgrade gcc in QNX 6.6.0 from 4.7.3 to 4.9.3. I downloaded the GCC and Binutils packages from
http://community.qnx.com/sf/frs/do/viewSummary/projects.toolchain/frs
I deployed the packages by copying files into qnx6.6.0's 'host' and 'target' folders, and setting compiler version 4.9.3
 in C:\qnx660\host\win32\x86\etc\qcc\gcc\default.
Then when I tried to rebuild my application in Qt Creator I got an error as below -
C:\qnx660\host\win32\x86\usr\bin\i486-pc-nto-qnx6.6.0-ld: ../../bin/x86/Release/sxm17_app: hidden symbol `
_Unwind_Resume' in C:/qnx660/host/win32/x86/usr/lib/gcc/i486-pc-nto-qnx6.6.0/4.9.3/libgcc.a(unwind-dw2.o) is referenced
by DSO
C:\qnx660\host\win32\x86\usr\bin\i486-pc-nto-qnx6.6.0-ld: final link failed: Bad value
cc: C:/qnx660/host/win32/x86/usr/bin/i486-pc-nto-qnx6.6.0-ld caught signal 1
make[1]: *** [../../bin/x86/Release/sxm17_app] Error 1
Any idea what problem it might be and how to fix?
In my experiment I did see that if I replace the new libgcc.a with the old 4.7.3 version then the error goes away. But
is it a good workaround or unsafe?
Thanks!
Eric
Re: hidden symbol `_Unwind_Resume' error with GCC 4.9.3 and QNX SDP 6.6.0
This was fixed recently and is available in the 4.8.3 packages. The 4.9.3 packages have not yet been updated.
Thank you Michael. Yes gcc4.8.3 works for me.
As I know gcc4.8.3 is not different to gcc4.9.3 regarding c++11 support. Is that correct?
Eric
Ok I find out one difference on c++11 support between GCC 4.9 and 4.8  is <regex>.
The docs outline what library support is available/missing:
https://gcc.gnu.org/onlinedocs/gcc-4.8.5/libstdc++/manual/manual/status.html#status.iso.2011
And there is also a status page for the compiler support:
https://gcc.gnu.org/projects/cxx-status.html#cxx11
I will try to get updated 4.9 packages up soon, but unfortunately I cannot make any promises.
For what it's worth, the 4.8 and 4.9 packages have been updated.
Updated as in available somewhere for download ?
RE: hidden symbol `_Unwind_Resume' error with GCC 4.9.3 and QNX SDP 6.6.0
Oh my bad I was looking at the creation date instead of last modified.
Thanks.
-----Message d'origine-----
De : Michael Daniels [mailto:community-noreply@qnx.com]
Envoyé : 4 juillet 2016 11:39
À : general-toolchain <general-toolchain@community.qnx.com>
Objet : Re: hidden symbol `_Unwind_Resume' error with GCC 4.9.3 and QNX SDP 6.6.0
Yup, updated the packages in the File Releases section:
http://community.qnx.com/sf/frs/do/viewRelease/projects.toolchain/frs.gcc.gcc_4_8
http://community.qnx.com/sf/frs/do/viewRelease/projects.toolchain/frs.gcc.gcc_4_9
General
http://community.qnx.com/sf/go/post116513
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
I am working with QNX Momentics on Windows and using QNX SDP 7.0.0 and GCC 5.4.0. I am facing the same problem with the
new GCC available here. Can you please help me in solving this error ?
Following is the error:
C:\tools\sdp\qnx700\host\win64\x86_64\usr\bin\i586-pc-nto-qnx7.0.0-ld: hcu: hidden symbol `_Unwind_Resume' in C:/tools/
sdp/qnx700/host/win64/x86_64/usr/lib/gcc/i586-pc-nto-qnx7.0.0/5.4.0/pic/libgcc.a(unwind-dw2.o) is referenced by DSO
C:\tools\sdp\qnx700\host\win64\x86_64\usr\bin\i586-pc-nto-qnx7.0.0-ld: final link failed: Bad value
cc: C:/tools/sdp/qnx700/host/win64/x86_64/usr/bin/i586-pc-nto-qnx7.0.0-ld caught signal 1
Raju
