Re: debugger stops working after first run
05/12/2008 8:48 AM
post7929
> I am running Momentics (4.0.1) on Windows and debugging an application on QNX
> 6.3.2. For some reason now when I debug, I can attach, add breakpoints and
> all works the first time. However if I then run with no breakpoints, I can no
> longer add breakpoints of even suspend the application. I get an error
> message saying the debugger failed to interrupt the process. This all used to
> work.
> Any ideas what the issue may be?
Yep, it's a known issue PR49354. IIRC, it was fixed in Windows host of Momentics in 6.3.2.
Ryan Mansfield
