python2.7 (gdb-prereq): missing _scruct module
01/25/2016 10:44 AM
post115606
Hello!
Seems than current python 2.7 build cannot work with gdb 7.x and Qt Creator IDE (Linux, at least with 3.2.0 and 3.5.1
versions of IDE).
Steps to reproduce:
- try to debug any Qt application using "Debug" button.
Result: Debug feature does not work, "Window-> Views-> Debugger Log" contains at least these error lines:
------------------------- cut ---------------------------
>&"Traceback (most recent call last):\n"
>&" File \"<string>\", line 1, in <module>\n"
>&" File \"/opt/qtcreator-3.2.0/share/qtcreator/debugger/gdbbridge.py\", line 14, in <module>\n"
>&" import struct\n"
>&" File \"/opt/650/host/linux/x86/usr/python27.svn/lib/python2.7/struct.py\", line 1, in <module>\n"
>&" from _struct import *\n"
>&"ImportError: No module named _struct\n"
(full log is attached)
help('modules') command also fails:
Python 2.7.2 (default, Feb 22 2012, 13:21:29)
[GCC 4.1.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> help('modules')
File "<stdin>", line 1, in <module>
File "/opt/650/host/linux/x86/usr/python27/lib/python2.7/site.py", line 466, in __call__
import pydoc
File "/opt/650/host/linux/x86/usr/python27/lib/python2.7/pydoc.py", line 55, in <module>
import sys, imp, os, re, types, inspect, __builtin__, pkgutil
File "/opt/650/host/linux/x86/usr/python27/lib/python2.7/inspect.py", line 41, in <module>
from operator import attrgetter
ImportError: No module named operator
Is any additional information needed?
Igor
